93 civic no start please help, descriptive diag inside im out of ideas
Old Oct 11, 2011 | 04:22 PM
inovative91's Avatar
Default 93 civic no start please help, descriptive diag inside im out of ideas
working on my moms car here,
1993 honda civic dx 1.5 sohc non vtec
issue: no start, starts 1 out of 200 times(estimated lol)
spins freely, full tank
items checked/tested:
new fuel pump-getting 42psi at fuel rail **tested**
replaced coil in dizzy
voltage tested tps**right on the money, no dead spots**
map sensor tested with known good part
iacv tested with known good part
all grounds checked and clean
timing checked and marks are aligned
ecu tested with known good part
compression tested 150-160 average per cylinder
spark plugs changed
spark tester shows spark but how strong the spark is i do not know
when(very slim) it starts it will idle just fine, and i am even able to drive it. when accelorating heavy it will buck and almost die when accelerating, as long as you ease into it , it will run. once you kill it, it will not start.
mom is currently here in houston visiting and can not go back home to austin until i figure this out. please if you have any suggestions let me know.
Thanks alot!
Old Oct 11, 2011 | 04:29 PM
Former User's Avatar
Default Re: 93 civic no start please help, descriptive diag inside im out of ideas
Click the spark link in my signature. You need to know whether spark is weak (orange or deep blue).
Any CEL codes?
Old Oct 11, 2011 | 06:32 PM
Changed igniter, coil tested good, n e other suggestions...need to get mom home..
Old Oct 11, 2011 | 06:50 PM
grumblemarc's Avatar
The Grumpiest
Color of spark?
Did you check spark? Is it weak?
Old Oct 11, 2011 | 08:49 PM
boostinb18c1's Avatar
Alternator? Mine almost did the same but i was able to tell because everything went sim in the car
Old Oct 12, 2011 | 07:35 AM
delsolintegra's Avatar
I replaced my ECU with a junkyard unit $135. Moisture corrosion of the circuit board. In dry weather the car might start. After a rain not a chance.
Old Oct 12, 2011 | 01:35 PM
Alternator is new, tried using another ecu that i took out of my car. will check spark again when i get home. checked it with a crappy spark tester from autoparts store, will try with ngk plug.
Pop in a can
Apr 20, 2017 06:03 PM
GarageNut
Jul 1, 2012 10:16 AM
Cav3man
Mar 24, 2012 03:44 PM
93civicdriver
10
Sep 16, 2010 11:45 AM
Hangmen
Oct 8, 2006 11:16 AM
