Trying to BAR my Civic SI. Need Help?
Old Oct 11, 2011 | 03:11 PM
gridline1's Avatar
Default Trying to BAR my Civic SI. Need Help?
I'm trying to BAR my ef civic si. need help please.
engine:
92-93 B18A1 all stock passes emissions tail pipe test. I have a P75 Intake manifold which came with the motor setup. I don't know why it came with it. But does not pass visual. i've changed the PCV routing and added stock intake box w/ arm. Is it possible to BAR my car with the original EF map sensor or would i have to get a 92-93 intake manifold and map sensor assembly?
Old Oct 11, 2011 | 03:23 PM
crx_si-r's Avatar
Default Re: Trying to BAR my Civic SI. Need Help?
You can get a pr4 intake manifold which is what 90-93 b18a1's use. Yes you can use a fire wall mounted map sensor. You will also need to use an obd0 or obd1 PR4 ecu along with matching components (such as distributor and o2 sensor)
Old Oct 11, 2011 | 05:32 PM
MarkOlson's Avatar
OG Hot Rodder
If you have a manual transmission, make sure you get an intake manifold from a manual Integra. We tried to BAR a manual CRX with a B18A1 swap with an intake manifold from an automatic Integra. It had an extra vacuum nipple, which we capped, but the smog ref made us go buy another intake from a manual car.
Effing little tin dictators...
Old Oct 17, 2011 | 12:20 AM
gridline1's Avatar
Right on for the info.
88 rex
Aug 16, 2005 06:49 PM
integra6650
May 19, 2004 12:32 PM
junkyardRx
May 17, 2004 03:53 PM
CNSK
Feb 24, 2004 10:11 AM
platinum00
Aug 17, 2003 06:16 AM
