95 Accord/LX head bolts re-usable or T2Y?
Old Oct 11, 2011 | 11:02 AM
mem94043's Avatar
Default 95 Accord/LX head bolts re-usable or T2Y?
Hi Accord gurus,
I am re-assembling the top end on a used 95 Accord I bought.
Question: Are the head bolts re-usable or are they Torque-to-Yield (throw away). I would assume they are re-usable since extensive searching online has not turned up any head bolt kits for this car. Would like to be sure though.
Your thoughts?...
Thanks!
Old Oct 11, 2011 | 03:23 PM
poorman212's Avatar
Default Re: 95 Accord/LX head bolts re-usable or T2Y?
re-use. if you were going for some hp build you could look in arp or something but a mild to stock....reuse them unless there is damage. normal rules-clean threads, lube, ect.....
Old Oct 11, 2011 | 08:17 PM
nus_dogg's Avatar
I've heard mixed reviews on these stock Honda head bolts. I've always buy new ones just to be on the safe side with OEM headgasket. I've heard a few re-used them with no problem; just that they torqued the headbolts like 5 more ft-lbs or something like that just to be on the safe side.
eddie7978
Engine Machining & Assembly
25
Feb 22, 2018 08:19 AM
iown2
Dec 23, 2011 05:10 AM
hob
Mar 7, 2008 05:45 AM
runderwo
May 17, 2006 10:48 AM
FloridaRacing.org
Nov 1, 2005 10:57 AM
