99 - SI- Turbo - Stalls while driving
Old Oct 11, 2011 | 09:10 AM
jjjjordan's Avatar
Default 99 - SI- Turbo - Stalls while driving
Hi,
New to the registration but have been a lurker for awhile.
CAR:
99 SI - 51K
Apex full exhust
Turbo - Hondata ECU, Tuned - Greddy Blow Off Valve
I bought this car off a guy that had all this work done. He claims it was tuned rich as the exhaust had a leak.
Here is situation.
Will drive about 15-20 min. No problems whatso ever.
I will park somewhere and maybe 15-20 min later move out again, this is when the trouble starts, the car will backfire, I have had it stall when accelatring (usually about 30-35 MPH) I get a CEL, but if i downshift it will give me the RPMS back.
I have had it stall at lights when I was slowing down to turn, I have had it stalled at lights. Everytime it takes a little bit to fire back up but does start. While its trying to turn over it smells like fuel is burning.
I have had this car for about 600 miles.
I have ran STP fuel injector through it alsong with 2 tanks of premieum. I just added 4 new spark plugs to it. (The guy had them in the trunk)
Here is my next solutions - I have read from forumns, but no body seems to have the same problems.
1) Clean throttle body
2) Voltage check the TPS
3) Fuel Filter
4) Possible Re-tune???
5) Coil
6) Plug Wires (They look okay to me)
Im stumped where to start. As I am not sure what the problem is.
Any help, maybe a start list or troubleshooting will be great.
Sorry about the long story, trying to get the entire picture out there.
Josh
Old Oct 11, 2011 | 10:32 AM
blackmugensivic's Avatar
Default Re: 99 - SI- Turbo - Stalls while driving
When you say that you ran two tanks of premium through it does that mean you're running regular? With a boosted car you have to run premium. Also did you gap the spark plugs before putting them in? What gap?
Sounds like an ignition problem
Old Oct 11, 2011 | 10:35 AM
grumblemarc's Avatar
The Grumpiest
Sounds like a bad tune to me. What are your AFRs? Are you running a wideband with a gauge? How do you know it's running rich? Verify the exhaust leak?
teddyca
Jul 1, 2013 06:07 AM
Arith7
Mar 29, 2009 09:45 AM
Civicvtihatch
May 19, 2005 07:58 AM
cerpher
Apr 26, 2005 06:54 AM
