Ls/vtec wont start need help..
Old Oct 10, 2011 | 06:42 PM
doubble clutchin's Avatar
Default Ls/vtec wont start need help..
0bd2 ls block mated with a b16a2 head...
just completed conversion and car will not turn over, checked timing and everything looks to be fine.Car is getting fuel and spark, went over each sensor and ground still no luck...Being that the is block is obd2 i'am stumped on the pvc system.Not sure if the lack of a the pvc system being conneted is my problem and if it is how do i solve it...
did a compression test and i got 180psi in 3 cylinders and 165psi at cylinder 2 what can be the cause of this? and could this be why the motor wont turn over? Any help would be greatly appreciated...
Old Oct 10, 2011 | 06:50 PM
mouab18c1's Avatar
Default Re: Ls/vtec wont start need help..
Is your starter even working properly?
Old Oct 15, 2011 | 07:12 AM
yes the starter works...the car cranks but won't turn over....help please...
Old Oct 15, 2011 | 07:52 AM
fcm's Avatar
fcm
Old Fart
Crank and turn over are the same thing, you mean engine turns over, [cranks] but will not fire, [start].
You would need to do a leak down test to see why cylinder 2 is lower then the rest, although it is not low enough to keep engine from starting.
Haccord1996
20
Jul 17, 2011 04:01 PM
GrnZ
Apr 1, 2008 05:14 AM
lilintegra25
Feb 8, 2008 07:26 PM
EndlessGarageEG6
Apr 26, 2003 12:34 PM
