brake issue
Old Oct 10, 2011 | 04:04 PM
titi_vtec's Avatar
Default brake issue
here is the story i took out my tranny put new clutch on it i put everything back on but i never touch a brake line or something relationated with it, and my car dont want to brake it start getting hard at the end only, i bleed all tires and still doing same i put new bracke master cylinder and bleed tires again and still same!!! some help pls
Old Oct 11, 2011 | 02:10 AM
titi_vtec's Avatar
Default Re: brake issue
Someone?
Old Oct 11, 2011 | 06:21 AM
titi_vtec's Avatar
Old Oct 11, 2011 | 07:01 AM
casedakid's Avatar
Check for a pinched line. Also Did you bench bleed the master cylinder?
Old Oct 11, 2011 | 07:52 AM
vman1993's Avatar
i had the same issue and changed the lines to braided lines.....seems to work for me!!! good luck
Old Oct 11, 2011 | 08:37 AM
Lugzilla's Avatar
Canuckian
Bench bleed your M/C if you haven't and bleed the lines again. If it doesn't make any difference, try using a c-clamp to push the brake piston all the way in then bleed the line again. Do it for each side and come report back here.
Old Oct 12, 2011 | 02:38 AM
titi_vtec's Avatar
I bleed The M/C and lines and i got all my lines good none of then are broke but i solve my problem already new brakes my rotor are in good shape so i put new calipers too and work done i apressiate all your help guys thanks you
Jtkdirtbike
Sep 8, 2013 03:48 PM
curtie94
Apr 9, 2011 05:01 PM
Jooleeus
Feb 24, 2008 09:20 AM
RockWolf
Nov 9, 2006 08:16 AM
DIYaccord
Apr 1, 2004 07:07 PM
