brake light indicator is on
Old Oct 10, 2011 | 04:03 PM
BayAreaPnoi_415's Avatar
Default brake light indicator is on
I have a 2000 Honda Accord sedan.
I noticed that my brake light indicator is on while I was driving then after a while of driving it turns off by itself. I checked my brake fluid, it's just below the max line and seems like everything is good to go. I also notice that if I warm up my car for 5-10mins before driving it, the brake light indicator never turns on.
Can anyone help me with this. Thank you.
Old Oct 10, 2011 | 05:45 PM
redbull-1's Avatar
Default Re: brake light indicator is on
It may be the master cylinder reservoir filter and possibly the float.
http://www.tegger.com/hondafaq/tsb/accord/x03-078e.pdf
Old Oct 11, 2011 | 03:12 PM
CDelgado220's Avatar
Are the bulbs out? On some older accords the bulbs are dual filament. One filament is for braking and the other for "parking" lights
Old Oct 12, 2011 | 09:22 AM
projectcord's Avatar
I have the same problem on my 94 but the light is dim and then when I pull the E-break up it gets brighter. I thought it might have been my break sicking or the switch but I didnt smell breaks burning after driving. I cant figure out what the problem is!
Old Oct 12, 2011 | 01:17 PM
KRITIK's Avatar
i have the exact same issue with my 91 accord
sometimes the light comes on as stays on wen i depress the brake pedal
Old Oct 12, 2011 | 06:11 PM
I think it might be my fluid. It doesnt look low enough to trigger a sensor or anything but im going to add some tomorrow and see if that helps
Old Oct 12, 2011 | 09:31 PM
theone786's Avatar
bump.....
Old Oct 14, 2011 | 04:21 PM
Lost Again's Avatar
Originally Posted by theone786
bump.....
What is this...
Trying to get a post count up.
Old Oct 14, 2011 | 05:01 PM
92accord19's Avatar
i have a 1992 honda accord 2dr and i had a short that kept popping fuses but fixed that and now my tail lights will not turn off unless i pull fuse,,idk wut to do
Old Oct 15, 2011 | 09:38 AM
Lost Again's Avatar
tail lights or brake lights....if brake lights, check the switch but more than likely it is the "stopper/plg" the swithc makes contact with...see any strange plastic pieces in the floor board?
Old Oct 15, 2011 | 01:04 PM
P_Adams's Avatar
I'm sorry if I sound like a dolt, but are we speaking of the "Brake System Warning Lamp", the "ABS System Warning Lamp" or the "Bulb Out Warning System" located in the Speedo Quadrant ?
If we're speaking of the "Brake System Warning Lamp", it can be affected by (yes) the Master Cylinder Reservoir sensor; But it can also be affected by a mis-adjusted Emergency Brake.
P
Old Oct 15, 2011 | 01:22 PM
redbull-1's Avatar
P
Wow! The great P_Adams is back.
moundsostuf
Feb 28, 2015 09:12 PM
SCinCA
Oct 6, 2014 06:35 PM
mnwildfan2k
Jan 1, 2014 07:53 AM
professorman
Oct 27, 2013 06:28 AM
'Accord Ex'
Jan 23, 2007 07:18 PM
