00 civic dx hatch will not start
Old Oct 10, 2011 | 03:01 PM
Jrox.chase's Avatar
Default 00 civic dx hatch will not start
My 2000 honda civic DX auto will not start. I have spark, it has gas. it turns over. just wont fire. Checked timing and its on. Plus I believe its an interference engine so if it jumped time I would/should have noticed. I do have low compression in cylinder 4 it comes in at 145, the rest are right around 210. I do have a cracked exhaust manifold, but that shouldn't matter. Any Ideas?
Old Oct 10, 2011 | 03:30 PM
virgineg6's Avatar
Default Re: 00 civic dx hatch will not start
How did you check for spark and fuel? Are your plug wires in the correct order?
Old Oct 10, 2011 | 04:41 PM
thangnhocngheo's Avatar
i have the same issue rite now.. imma tow it to a mechanic tomorrow... have u check ur dizzy?
Old Oct 10, 2011 | 11:54 PM
Jrox.chase's Avatar
I have not messed with the order of the plug wires prior to this issue, so I am sure that the plug wires are in the correct order. I checked for fuel by by removing the fuel line connected to the fuel rail and had a buddy bump the key, plenty of fuel flows out. I checked for spark by pulling a plug and grounding it to a bolt on the heatshield for the exhaust manifold.
Old Oct 11, 2011 | 01:19 AM
HondaPartsHero's Avatar
Technical Hero
What color is the spark? Could be weak. Have you pulled a plug to see if its burning the fuel or if the plugs are fouled? Have you check to see if the timing belt is broken?
Old Oct 11, 2011 | 01:30 PM
Jrox.chase's Avatar
If the timing belt was broken the dizzy would not turn, and there would be no spark. No the spark is weak. it looked good.
Old Oct 11, 2011 | 03:26 PM
Former User's Avatar
Why ignore low compression in cyl 4?
Old Oct 11, 2011 | 03:37 PM
Jrox.chase's Avatar
Come tax time I am gonna do the mini me swap or do a b16a2 swap and manual swap. I just need it to get me through till then. even with low compression in one cylinder with 3 good ones it should still fire right?
Old Oct 11, 2011 | 03:54 PM
If spark is bright white at all 4 plugs, all 4 fuel injectors spray fuel, and the mechanical timing is dead on, then the low compression in cyl 4 is the best explanation.
Old Oct 11, 2011 | 04:57 PM
Jrox.chase's Avatar
We got the thing to start. put plugs, wires, cap and rotor. This will get me threw until mini me swap time.
DansaHondaMan
Aug 26, 2013 10:28 AM
REDEM1FTW
18
Nov 6, 2010 06:08 AM
Since 1983
Nov 15, 2009 10:24 PM
trecool44
Jan 11, 2008 10:46 AM
2ndGenREX
11
Jan 13, 2007 01:50 PM
