crank pulley damage
Old Oct 5, 2002 | 03:24 PM
brea1's Avatar
Default crank pulley damage
hey guys should i use my stock crank pulley on my f22b or one from an h22,23? Mine is chipped where the power steering belt goes.
Old Oct 5, 2002 | 04:04 PM
SOHCArchangel's Avatar
Default Re: crank pulley damage (brea1)
f/h crank pulleys are the same
Old Oct 6, 2002 | 08:04 AM
Itsstock's Avatar
Default Re: crank pulley damage (SOHCArchangel)
Spend the 80 and replace it, The pully is balanced, if there is a chip on their that can potentially damage the engine through time,
Also you can risk ripping belts if the damage is really bad,
Save yourself the headache and just buy an aftermarket replacement, I bought 1 from honda for around 80, for a 99 accord
Old Oct 6, 2002 | 08:34 AM
2000Accord5sp's Avatar
Default Re: crank pulley damage (Itsstock)
exaclty what he said. Also I would double check that the two engine's crank pulley are the same. I was 'told' (so my advice is purely based on some crack dude at honda) that they have different part numbers. So if that IS true, they might just look identical but be different in weight or something. If that's the case, make sure you get the right crank put on there.
devilpuppy
Aug 30, 2024 09:15 AM
bks84
Engine Machining & Assembly
Jun 29, 2015 01:51 PM
DARKTEG_
Aug 13, 2006 03:15 PM
accord91lx
Dec 26, 2003 11:09 PM
3700 Vtec
Jan 21, 2003 05:55 PM
