Function Form Type 2.5s!!!! CHEAP!!!
Call or Text Joel 909 728 9967!!
The current Type II.5 Coil-over models are modified and retooled from the previous versions. The new and improved Type-II.5 coil-overs are complete coil-overs with a fully threaded shock body. Through extensive research and development, Function and Form has enhanced an already largely successful product to a complete coil-over system that any car enthusiast will find irreplaceable.
* 32 levels of dampening adjustment!
o Dampening adjustments are made with a **** that distinctively clicks at each level.
* Steel construction of lower mounts for maximum strength.
* Adjustable front camber plates.*
* Adjustable pillowball mounts.*
* Adjustable ride height from bottom mount.
o Allows users to retain full shock travel even under maximum drop.
* Special oil lubrication to withstand conditions from -40 degrees Celsius to 200 degrees Celsius.
o Allows shock to perform even under the most demanding conditions.
* Dual tube shock design for maximum ride comfort.Wireless dampening controller (wi-damp) available for most applications.
* Spring Rates: CUSTOM - CHOOSE ANY RATE
* *Pillowball mounts and front camber plates are only available on certain applications.
Function and Form partnered with Eibach to offer an even more improved coilover model using Eibach’s ERS motorsport springs! Benefits include reduced unsprung mass and stricter spring rate consistency. Custom spring rates are also available in 8kg/mm, 10kg/mm and 12kg/mm. This is a perfect upgrade for the user who wants maximum Function and Form performance. Refer to manufacturer’s website for more info. After ordering, contact us with the desired spring rates.
HardParkedCom
461
Oct 3, 2012 06:07 AM
Honda Gen
12
Nov 15, 2008 11:36 AM
