93 del sol lights/many other q's
Old Oct 10, 2011 | 08:03 AM
scerbz's Avatar
Default 93 del sol lights/many other q's
hey, i have a 93 del sol, and it has so many little things wrong with it.
it steers a little odd/feels like loose handling. i know it does not have sway bars, and doesnt need ball joints. tie rod ends were just done. still feels loose. shakes cause cant balance tires. what else is there?
as well, my gauge and tail lights went out at the same time the other night. there were so many extra wires ran for so many different things, none of which are connected. no fuses popped. what is the deal?
how can i wire up the cig lighter/accessory outlet, since mine isnt connected?
i have the 1.6l d16z6 engine out of it currently, and am wondering what i ought to do, it has 150k and runs pretty good, but im curious what performance upgrades would be best? suggestions for if i should rebuild/clean it?
with all those things, i have it torn down basically stripped. im wondering how to fix all these things, if i should do it up and rebuild it all beautifully/paint, just put it back together, or maybe part it?
Old Oct 10, 2011 | 12:29 PM
scerbz's Avatar
Default Re: 93 del sol lights/many other q's
no one knows anything? bummer
Old Oct 10, 2011 | 12:36 PM
grumblemarc's Avatar
The Grumpiest
People tend to not want to answer posts that have issues in them that are all over the place.
Why can't you balance the tires? Never heard of that one.
No answer to your fuse question. Don't really know what it is you're asking.
Do what you want with the engine. That's not really a tech question.
Again, not a tech question. Weigh the pros and cons and decide what you want to do.
Old Oct 10, 2011 | 01:10 PM
dodken's Avatar
Sounds to me like a connection some where fell apart. If who ever did it was lazy and did not make proper connections aka "E taping" wires together one may have just fallen apart over time.
Old Oct 10, 2011 | 01:36 PM
Neldawg80's Avatar
Electrical problems are the worst.
Perhaps your control arms are bad.
Old Oct 10, 2011 | 08:36 PM
scerbz's Avatar
exactly what im wondering is where it might be, but yeah, time to trace the lines, ugh. i dont like doing so that much.
how would i know if the control arms are bad?
Old Oct 17, 2011 | 07:44 AM
scerbz's Avatar
anyone got a clue as to what would cause both the cluster lights and the taillights to go out at the same time?
harlowz
Oct 12, 2010 08:16 AM
1LowSol
Dec 22, 2008 11:03 PM
RusBear
Feb 11, 2005 08:23 PM
