Distributor: OEM or Aftermarket
Old Oct 9, 2011 | 01:29 PM
ttmix's Avatar
Default Distributor: OEM or Aftermarket
Need a Distributor for my 1999 Accord LX 4 cyl. Question: are the aftermarket brands worth the risk? Difference between a Hitachi new vs remanufactured? Trying to save $$, but don't want to purchase a headache.
Thanks
Old Oct 9, 2011 | 02:39 PM
accordmatt's Avatar
Default Re: Distributor: OEM or Aftermarket
go with stock replacement unless ur going msd. hitachi is so well known cuz thats what honda uses. going with a knockoff here is not the place to skimp on ur timing and spark
Old Oct 9, 2011 | 02:41 PM
ttmix's Avatar
Thanks, that's what I figured. Any thoughts on a remanufactured Hitachi? Appreciate the help.
Old Oct 9, 2011 | 02:45 PM
92teginsc's Avatar
usually when buying a knock-off you will need to replace the internal parts almost right away as i have had to do in the past. i suggest you get an oem unit!
Old Oct 9, 2011 | 02:53 PM
accordmatt's Avatar
reman hitachi uhhh no maybe a reman from parts store so if its bad get ur $ back but... all up to u. reman still run risk of off timing/spark
Old Oct 9, 2011 | 03:45 PM
ttmix's Avatar
Sounds like I should go brand new. Thant's what I needed to know.
Thank you much.
SallyTegra
Mar 2, 2016 10:36 AM
andyandrew2006
Jun 10, 2014 01:57 PM
Paegelow
Oct 6, 2011 03:35 AM
cvc1393
Nov 19, 2009 08:05 PM
2DoorBandit
22
Jul 4, 2008 01:01 AM
