front right turn signals dont work . WHY?
Old Oct 9, 2011 | 12:10 PM
chris riz's Avatar
Default front right turn signals dont work . WHY?
the back one flashes fast but thats about it.
both the front bumper and the one next to the headlight dont work
i changed the bulbs that didnt work . I also changed out the fuse ( even though it was good.)
i need help before the cops use it as an excuse to pull me over
can anyone give me info on what to test ?? or what to do next???
thanks
Old Oct 9, 2011 | 01:22 PM
Efhatch277's Avatar
Default Re: front right turn signals dont work . WHY?
Have you checked all connecting wires to those lights?
Old Oct 9, 2011 | 01:28 PM
chris riz's Avatar
What do you mean ?
I checked the wires and they are not damaged.
I did a little reading and looks like there is a relay for the turn signals.
Does anyone know where I can find it ?
Car is a 91 SI
Old Oct 9, 2011 | 04:39 PM
chris riz's Avatar
is there a relay switch that i dont know of?
Old Oct 9, 2011 | 09:10 PM
Beyond Imagination's Avatar
your flasher relay should be functional if your right rear signals are working yet blinking faster. check to make sure you are getting power & ground to the right front signal. a wiring diagram would be helpful if you are unsure what wire is power/ground.
Old Oct 10, 2011 | 07:53 PM
chris riz's Avatar
Sounds good I'll give it a shot and update tomorrow
Old Oct 10, 2011 | 08:02 PM
monster d's Avatar
when is flashes fast that means you have a short.
Mine does the same thing for the right blinker...the tail and headlight blink fast but the bumper blinker won't blink. I can hit it a couple of times and it'll go back to normal but when i drive it'll go right back to shorting.
I have checke the wire for damage of any sort and I can't find any. Mine is an 89 si gl and lmk what you find out bro.
Old Oct 12, 2011 | 04:33 PM
chris riz's Avatar
So I opened up the harness under the hood it turned out to be the harness had bent somehow and the wire had torn.
I soildered it back together and shrink wrapped it and it was good to go.
hybridnorth
37
Feb 16, 2019 06:13 AM
jhammond_82
Jan 31, 2009 08:11 AM
Nerrej
Oct 21, 2008 09:35 AM
layedoutat0psi
35
Sep 21, 2007 04:48 PM
si90rex
Aug 10, 2006 09:54 AM
