axle stuck in hub
Old Oct 9, 2011 | 07:56 AM
SR20S13's Avatar
Default axle stuck in hub
well as it says, i'm trying to remove the axle from my b18 swapped hatch, well when we pulled the motor we couldn't get it out so now its sat since then and well it still won't come out, i've beat the crap out of it (hitting a piece of wood to not mushroom the head) but now i'm fresh out of ideas? Should I just take the whole knuckle off (since i'm already doing that to replace all the bushings) and just have the shop press the axle out?
Old Oct 9, 2011 | 08:08 AM
grumblemarc's Avatar
The Grumpiest
Default Re: axle stuck in hub
I think you answered your own question.
Old Oct 9, 2011 | 05:10 PM
pwebb0207's Avatar
you will have to sacrifice an axle nut for this method, but it might be worth it to you:
thread the axle nut onto the axle, leaving a few threads hanging over the edge. this is what will be absorbing the impact.
grab a 5 pound sledge hammer and give it a good solid whack.
make sure you're doing this with all the suspension pieces still connected. if not, force will be absorbed and not directed into the frozen axle splines.
Old Oct 10, 2011 | 08:33 AM
hondamark35's Avatar
for the longest time a block of wood (or brass hammer, or anything softer than the axle stub...) in front of a 2lb sledge did the job for me. recently i've run into 2 or 3 very stubborn axles that just shrugged off my efforts.
i did two things that i think may help you out. first is to soak the splines with penetrant then immediately give it a "push" from an air nozzle. you want to use just enough air pressure, not too much. you'll see it working when you get it right.
the second thing was using a large 3-jaw bearing puller to force the axle out of the hub. i've broken a cheap puller doing this, but a higher quality puller worked like magic.
Old Oct 11, 2011 | 09:54 AM
Markb16a's Avatar
this is why you Grease the hub. I learned my lesson when this happened and ruined a hub and had to buy another one. But if you are replacing the bushings and having to take the spindle off just take it to get it pressed out. A machine has more force than a human being lol. I hope you got it out btw. Good luck.
Old Oct 11, 2011 | 12:29 PM
XelginX's Avatar
what i do is make sure you have the axle removed from the trans so its hanging and you can get a punch for a air hammer thats fits in the little dimple of the center of the axle and it will pop it right out every time.
Old Oct 11, 2011 | 01:40 PM
this one! i like that idea.
Old Oct 11, 2011 | 08:43 PM
10psiLsEf2's Avatar
My ef kicked my *** so i called my tool guy and bought me a air hammer!!!!! Bit&# came right out,
Old Oct 11, 2011 | 08:53 PM
em1pusha99's Avatar
I've had this happen to me, heat that some bitch up with a torch then use a brass punch and BFH, give it a good whack, should come out. But first smooth out that mushroom you've got going on because that will only fight you more on the way out. But heat is a mechanics best friend lol
Old Oct 12, 2011 | 08:04 AM
Muckman's Avatar
Moderator in Chief
I dont see how you could have mushroomed hardend steel with hammering on wood. I use a 1/2" extension right ont he axle nose and tap it through. But as suggested use heat if its stuck.
Old Oct 12, 2011 | 09:04 AM
it's not hardened all the way through and if the hardened area extends even to the splines from the CV bell it wouldn't continue to the threaded area.
I've found if it's stuck hard enough to require a good pounding (sufficient to mushroom the end) the wood block won't always transfer enough energy and may just break apart before the axle has budged.
Old Oct 14, 2011 | 05:01 AM
eldermichael's Avatar
As many said above. Use heat and something extremely solid pressed firmly against the axel.
01ethansh
Dec 17, 2008 12:15 PM
LS94tegra
Apr 19, 2008 11:59 AM
dextR
Sep 16, 2005 07:49 AM
Feb 19, 2004 08:54 PM
