98 Civic LXI 1.5L cranks but does not start? pls help.
Old Oct 9, 2011 | 03:25 AM
mohdmo's Avatar
Icon6 98 Civic LXI 1.5L cranks but does not start? pls help.
fuel pump is ok, the fuel reaches the motor, the coils has electricity, spark plugs are new, and the coils have spark, the car cranks very good but no start...
any ideas may help, am thinking of the oxygen....
Old Oct 9, 2011 | 03:41 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Honda Civic LXI 1998 1.5L cranck, but does not start? pls help.
What color is the spark?
Old Oct 9, 2011 | 04:39 AM
ADuffett's Avatar
How old is your battery. I had the same issue and I replaced my battery and it started up.
Old Oct 9, 2011 | 06:10 AM
Former User's Avatar
Default Re: 98 Civic LXI 1.5L cranks but does not start? pls help.
Are the plug wires installed in the correct firing order on the cap?
Do the injectors spray fuel?
Have you checked the mechanical timing?
Old Oct 9, 2011 | 06:05 PM
CarelessFeather's Avatar
Can you smell gasoline when you remove the spark plug? If no that means the injectors are not spraying.
Old Oct 9, 2011 | 07:45 PM
easy_vtec's Avatar
Have you checked your 101 ground on the back of the t-stat housing?
civic2sick
Feb 26, 2020 09:39 PM
Arandomuser
24
Sep 12, 2013 04:33 PM
fooboo
May 22, 2010 01:53 PM
acuragsrmemphis
Mar 4, 2010 06:43 AM
milanoteg
Sep 12, 2009 08:35 PM
