honda cancer help
honda cancer help
Got an eg coupe. With a lil rust on the passanger rear wheel well. Its not all the way through but looks like someone either put something on it or jus painted over it. I have read a few threads on this.. some say replace panel.. some say grind down.. jus depending on damage. Well mine is just on the very edge of rear wheel well about size of a dime. Replace? Or fix? If so how should I do so? Ill post pics when I get home
Re: honda cancer help
Just curious, what color is it? If you patch it with fiberglass and just primer and spray over it, it might last a year or two. The only *real* fix for rust is to cut it out and weld in new metal but that is ALOT of work.
Lol this guys always got some smart aascomment. Go put ur 2 cents in somewhere else dude or lose the attitude n quit writing on my threads if im such an idiot. Lmao smh...
The Grumpiest
Only if it's surface rust. Which it probably is NOT. Sorry you think me being blunt is smartass. You ask about bodywork but know nothing about bodywork. If you remove rust OF COURSE you have to replace the sheet metal. Do you know how to do that? Do you know how much metal to remove? Do you know how to weld in the new? DO you know anything about Bondo? Filler? Painting? Probably not.
I think he was implying that the only real way to fix it is the replace it. Check what is under the paint. I recently looked at a civic that only had a little bubbling on the outside but the metal had rusted through in several places and I had to glass it up and even that didn't last too long. It rusts from the inside out.
Yeah all except for welding. Jus quit writing on all my threads dude tryna act like ur god an u kno everything ok. I don't work at a body shop an was asking for tips so I don't need your bullshit go talk **** to someone else lil guy
The Grumpiest
Not one time did I disrespect you but you come at me with the name calling. All you new guys with the attitude need to check yourselves. If you really knew about body work I don't see why you would need to ask anyone's advice.
Point blank. Until you start removing you have NO IDEA how extensive the rust damage is. It's like an iceberg. what you see may only be the tip. And BTW, I can post any where I damn well please. YOU posted on a public forum.
Cool thanks guys that's all I wanted. And I don't kno everything about body work cuz if I did why would I b asking???? Everyone can use extra input..
I had a couple of rock chips on my del sol that had rusted, but the metal was good underneath. I just ground it down to bare metal and a good inch or two around it and use the primer that converts the rust (forgot the name).
It is called pickle-x or phospho. It is a dilute phosphoric acid sollution. Works okay in the short term. Make sure you cover it with some sort of top coat, otherwise it will rust again. The problem with the rear wheel arch is how it rusts (inside out) as opposed to rock chips that surface rust and then it eats deeper into the metal.
Well as. I look under wheel well it feels solidan don't see any rust underneath. It looks like otstarted to surface rust an someone used some goopy **** to try n cover it up so I need to start Sandin an see how deep it really is. Thanks guys
The goopy **** could be bondo, POR, or brushed on primer. Remove all of it to inspect damage. Bondo can cover some serious flaws. Just because metal "Feels" solid, doesn't mean it necessarily is though. Good luck!
I suspect it's caused by the damn rubber edge clipped to it (it keeps the moisture/dirt inside - at least on EGs).
I have very, very light rust on there and now I am wondering if it is really coming from the inside.
I was planning on waiting a few more months until I can get her a new painjob, but looks like I'll have to take a look at that soon to contain the damage.
Yep, this sucks.
i know a guy that traded a knocking z6 for a shell from washington that had a "little" rust on the outside. LMAO two days later he was trying to take out the trunk carpet and his screwdriver busted through the outside of the rear quarter panel. didnt look too bad on the surface, just some bubbles. he ended up selling it to the junkyard lol
http://www.fixmyrust.com/1992-1995-civic-coupe--MZ.html
Go here and buy a new rear wheel arch, remove the whole panel, or cut off a section and weld the exact same piece back on.
There is also a topic on civiceg.com by Teal that shows how to fix honda rust http://civic-eg.com/viewtopic.php?t=24
i dont know why people bad mouth bondo so much if you dont want to spend 3 grand on body work then learn to fix it yourself for less than 50 bucks provided you have tools and sanders handy. just dont do a half assed job take your time with the coating and sanding it will look really nice when its finished properly.
P.S: Bondo can trap moisture to your metal and accelerate rusting, even if top-coated.
Seagull Management
If you live anywhere that stuff rusts it'll start popping back through within 6 months, that's a lot of wasted time and effort. Weld in new metal and use bondo to fix minor imperfections.
