Best Sway Bar Kit to get????
Old Oct 8, 2011 | 05:20 PM
vtec25's Avatar
Default Best Sway Bar Kit to get????
Just need to know whats the most complete kit i can get. Meaning with all brackets for a base model EF. Need the company name and if possible parts number and/or place to order them. I need both front and rear.
ThankX
Old Oct 8, 2011 | 06:12 PM
RussLaviolette's Avatar
Default Re: Best Sway Bar Kit to get????
Progress Technology. Google their website. 22mm bar is an A+ product! You won't need a front bar.
Old Oct 8, 2011 | 07:17 PM
coot_er's Avatar
For autocross, the 32mm ASR bar is the best. For daily driving, it probably doesn't matter. Just paint it yellow and tell people its JDM.
Old Oct 8, 2011 | 08:10 PM
CW-ITR's Avatar
I was going to ask you a question as what would be your intension behind the set up? After re-read your question, I understood. Here is what you are looking for:
http://www.andysautosport.com/honda/...ion/sway_bars/
Old Oct 8, 2011 | 09:11 PM
asianflava's Avatar
You're pretty much limited to Progress ans Suspension Techniques.
Old Oct 9, 2011 | 10:29 AM
Tyson's Avatar
mugen rear 22mm. its jdm. you wouldnt recognize it vs the oem one... its not painted yellow.
tanabe has a 20mm rear bar. they use a stronger steel they claim, so its a stronger relative stiffness... i dunno how much, or if its more than a typical ST bar. but its a direct fit for Si's.
just go with the ST rear bar. you dont want the front.
Old Oct 9, 2011 | 03:54 PM
vtec25's Avatar
So u guys suggest not to get a front sway bar? Even if i can find a oem one?
And i dont want it for bling. I plan to take my car autocrossing and track meets.
But i'm afraid of ordering a kit thats made for a si etc. that came with one already.
Old Oct 9, 2011 | 04:16 PM
BLU CIVIC's Avatar
Track Advocate
then i guess you need to educate yourself on stay bars. what are your current spring rates or what do you plan on running in the future? also, how are you wanting your car to behave? all of that will dictate the size and if you'll actually need a sway bar
Old Oct 9, 2011 | 04:47 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
I have the ST front and rear bars. by far the best improvement in the road feel of the car.
Old Oct 9, 2011 | 04:53 PM
You have a couple choices as everyone has mentioned.
ASR, Suspension Techniques, Mugen, etc.
ANY bar larger than OEM diameter will require reinforcing the subframe. Most purchase the ASR subframe reinforcement kit, but this is one of the most costly options.
Progress offers a kit with EVERYTHING necessary for around $188+S/H. Click here for that.
I recommend it because I have it. I powdercoated all my hardware and bar black to be more subtle.
vtec25's Avatar
Current rate is as follow 10k Front & 8k Rear. Tires Toyo Proxes R888 205/50/15.
And i rather have oversteer than under but overall i want to be flat. I hate body roll.
Old Oct 9, 2011 | 04:58 PM
The link I posted also details the rationale of sway-bars.
Old Oct 9, 2011 | 07:58 PM
Tyson's Avatar
no.
not at all.
perhaps youre confused. you should give your advice here. this just isnt true with EF's.
Old Oct 10, 2011 | 08:18 AM
Todd00's Avatar
I said I don't want a title!
Can the Mugen rear swaybar still be found? I remember looking for one 10 years ago with zero success.
And FWIW, I hated the ST rear bar. Coupled with that and all of the hardware it needs, it added significant weight.
Old Oct 10, 2011 | 08:39 AM
TearSDMF89dx's Avatar
if you plan on autox then you would only need the rear bar...no front bar =better turn in and grip through corners....on the rear youll definitely have to figure out how stiff it should be to get the rotation you desire too big = snap oversteer
Old Oct 10, 2011 | 08:41 AM
4drEF's Avatar
Keyboard Humorist
Originally Posted by Tyson
no.
not at all.
X2
Old Oct 10, 2011 | 04:14 PM
no.
not at all.
My apologies. I notice that the CRX rear bars mount differently than the EG and later.
Old Oct 10, 2011 | 07:38 PM
90_EX_Civic's Avatar
get a front sway bar. it'll help in keeping the front tires planted when in the turns. basically helping you from picking up the inside front, or more like a floating feel. plus it aids in some steering.
now saying that, you have a few choice's. a lot of the season vets that autox run the HF front sway bar, it's the smallest bar you can get for our cars. that way it won't be so big that you'll understeer, and not so small that it would not benefit.
for the rear everyone runs the ST rear bar. it's got a lot of hardware but it is the best you can get while mounting close to the stock location.
now saying that, you never said how much experience you have, and you can't have a car set up for autox, and do track events. oversteer will be prominent. a track car for autox, is doable, and you should follow this route if you plan on doing a lot of track events.
if you are just starting, just run what you got, and figure it out from there. seat time is a lot better, and more cost effective.
Old Oct 11, 2011 | 12:27 PM
Todd00's Avatar
Let's be completely honest here. Stock Si swaybars (front and rear) will be plenty if you choose your springrates correctly (unless your running national level soloII or IT races).
Don't randomly buy a swaybar until you figure out what it is you want the car to do. Example: There is absolutely zero point in running the ST rear swaybar if all you do is daily drive the car.
How can anyone "recommend" swaybars if we don't know what you're doing with the car?
Old Oct 11, 2011 | 01:10 PM
BLU CIVIC's Avatar
Track Advocate
Old Oct 11, 2011 | 06:05 PM
ef.91's Avatar
I bought some password jdm ones for my front and rear but the front wouldn't fit bc I have a 1.5 and the intake manifold is in the ways as well as the proportioning valve bc I bought a 3point one. Now I am having trouble returning the front one through password. The bars look dope and the rear made a big difference overall.. Just have to do a swap to make the front fit and I'm not ready yet. Password jdm is being hella gay so I don't recommend them. Even though their parts are pretty sick, the company is shitty.
Old Oct 11, 2011 | 06:27 PM
BLU CIVIC's Avatar
Track Advocate
i believe you are confused...conversation is about sway bars not strut tower bars
Old Oct 11, 2011 | 07:51 PM
ef.91's Avatar
Oops yea you're right. I haven't got into sway bars on my car yet
Old Oct 12, 2011 | 01:36 AM
blaak-crx's Avatar
SEARCH DAMN IT!!!!!!!!!!!!!!!!!!!!!!!
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/ef-sway-bars-1885416/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-rear-sway-bar-you-running-2430343/
ST = simplicity and using stock mounting points
Progress + subframe re-enforcemeent
ASR: $ (well adapted complete kit)
Blacknight117
Suspension & Brakes
Apr 15, 2012 02:56 PM
SamC
Oct 17, 2005 03:02 PM
MikeyDB7
Jan 21, 2004 11:22 PM
KillerWabbit
24
Jan 7, 2004 04:31 AM
grandmasterflex
Dec 10, 2003 05:00 AM
