Rebuilding hydrolocked engines??
Old Oct 5, 2002 | 01:51 PM
gheydeem's Avatar
Default Rebuilding hydrolocked engines??
Is it possible to rebuild an hydrolocked GSR engine? It sucked up some water and has a whole in the front of the block.
Would the head be useable still cuz I know the block is shot to ****, just needed to know.
Old Oct 5, 2002 | 02:00 PM
thegrinch's Avatar
Default Re: Rebuilding hydrolocked engines?? (gheydeem)
you can still use the head but you probably should have the head magnafluxed to check for any cracks.
Old Oct 5, 2002 | 06:25 PM
RAF LTD.'s Avatar
I assume you are using a CAI w/o a bypass. if this is the case then
Old Oct 5, 2002 | 10:15 PM
3rdGteg's Avatar
Default Re: Rebuilding hydrolocked engines?? (RAF LTD.)
Yeah you can rebuild it, just jb weld the block and slap the head back on...j/k
trash that block and rebuild the head if there's no crack via the results from the magnafluxing.
sh!ft
Appearance Build Threads
12
Nov 10, 2014 06:34 PM
fitbkeco
Mar 11, 2013 06:27 AM
scorp965
Jun 13, 2009 08:25 PM
EH3SiGRL
35
Apr 5, 2007 01:07 PM
vultron
Dec 30, 2003 03:23 AM
