1994 civic dx wont turn on.HELP!!
Old Oct 7, 2011 | 11:01 PM
Venomous 03's Avatar
Default 1994 civic dx wont turn on.HELP!!
Ok.so i changed the head gasket on my civic.turned the key and turned right on.after 10 minutes of running the car just shuts off.car wont start.
Cranks fine.i smell gas at the exhaust.checked for spark,no spark.checked the ecu fuse but its ok.turn key to on position,relay clicks,fuel pump primes,BUT i dont get the Check Engine light.it has to appear for 2 seconds and turn back off but it doesnt.all i see is the battery light and the srs light come on.i need some help!
Engine is d15b7 non vtec.
Old Oct 8, 2011 | 01:01 AM
virgineg6's Avatar
Default Re: 1994 civic dx wont turn on.HELP!!
Bulb possibly burned out, how did you check for spark?
Old Oct 8, 2011 | 08:11 AM
adv_blue's Avatar
have you checked the ecu?
Old Oct 8, 2011 | 05:00 PM
Bulb?? I took out spark plug and wire and told my friend to crank it while i hold the spark plug barely touching a ground.no spark.
Tried changing main relay.didnt work.how can i check the ecu?
Old Oct 10, 2011 | 06:25 AM
tqdanny's Avatar
i have this car and have had very similar problem.
first i found that my igniter in my dizzy was out but i ended up buying a new one because my rotor was beyond repair SMH -_-
after all that she cranks right over...
then i had a compression problem with my oil rings.. they completely blew.
This car was the biggest mess when i got it.. previous owners sucked!
so now im rebuilding.
If you have anymore questions hit me up maybe i can include some other trouble shooting that isnt listed
EKcpe00
Nov 14, 2010 02:27 PM
ampere
Jul 19, 2008 12:10 PM
sirjmj
Jun 21, 2008 09:06 PM
ywsek
Feb 15, 2006 01:11 PM
TD or Not TD
Dec 19, 2005 02:19 PM
