92 accord ex wont start unless push started
Old Oct 7, 2011 | 04:57 PM
tehtyler's Avatar
Default 92 accord ex wont start unless push started
ok ive got a 92 accord ex that will not start or even turn over. all it does is click once when you turn the key (no its not the battery it only clicks once) but the thing is you can push start it and it will start right up and run fine. i have changed the starter with a brand new one and changed the battery any suggestions will be apprecaited thank you for you time
Old Oct 8, 2011 | 05:55 AM
poorman212's Avatar
Default Re: 92 accord ex wont start unless push started
Terminals are clean and tight both ends of the cables.
What is the voltage at the small wire on the starter when someone tried to start it.
Last, find a strange plastic piece in the floor board lately.
Old Oct 8, 2011 | 06:59 AM
tehtyler's Avatar
both terminals are tight and clean and i already twisted the wires under the dash by the clutch. i will check the voltage and get back to you
Old Oct 8, 2011 | 09:57 AM
jamzx3's Avatar
hopefullyyou can figure this out...my crx does the same thing....all i hear is the acc. relay click when i try to turn it over....gl
Old Oct 8, 2011 | 01:50 PM
exb18c1's Avatar
Do the voltage drop test on positive and ground cables to begin with.looks like there is not enough voltage to turn the motor.
Old Oct 8, 2011 | 05:54 PM
angelEG6's Avatar
your starters bad, if your starter is bad you can still turn on your car but like u said u have to compression (push start) start it, but if it was somethin else your car wouldn't turn on even if you wanted to push start
Old Oct 8, 2011 | 08:45 PM
thiendegigolo's Avatar
try starting it with the key and have a friend or somebody else use the end of a broom to tap on the solenoid of the starter at the same time.
Old Oct 9, 2011 | 05:51 AM
tehtyler's Avatar
well i i ghetto rigged my car to were it starts now. what wrong is the starter isnt getting power but i can take a peice of wire and touch it from my positive termanil to my starter and it starts right up. so instead of finding the short in the wire i just ran a new one and it starts everytime. thanks for the help guys
Old Oct 9, 2011 | 06:28 AM
Lost Again's Avatar
Clutch switch.....there should be two on the clutch pedal.....but you got it going.
Blue93Dakota
Apr 13, 2015 04:27 PM
gandalf
Aug 24, 2009 04:39 PM
djryan
Jul 13, 2007 03:37 AM
voodooutt
Feb 11, 2007 12:20 PM
roxics
Jan 6, 2007 10:18 PM
