ccant set timing belt tension
Old Oct 7, 2011 | 04:32 PM
EK FLY's Avatar
Default ccant set timing belt tension
i need some help trying to set proper tension on my f22b1 ,
here is what i do but unable to set proper tension
1:set timing marks ( with lower belt cover on ) on the crank pulley
2: set timing mark on cam pulley , up , rear mark lining with head edge
3: tensioner pulley is loose
4 : set t-belt on both pulleys
5: rotate crank counter-clockwise 3 to 4 time
6: tight the 14mm bolt of the tensioner pulley
and my belt still have some slack in front and back ,,,,,,,,,,,,,,,,,,,,,
help plz i been cursing and yelling all by my selft in my garage all morning bc of this
Old Oct 7, 2011 | 04:35 PM
brakedrum's Avatar
Default Re: ccant set timing belt tension
Try it this way:
1.Tighten the tensioner 14mm bolt and then back it off 1/4 of a turn.
2. Turn the crankshaft counterclockwise (the direction the engine runs) until 3 teeth on the cam gear have gone around, you can tell this by looking at the little hatch mark on the cam gear and counting 3 teeth as it turns. After you have done this, then,
3. Tighten the tensioner 14mm bolt. The belt should be at specified tension.
Old Oct 7, 2011 | 04:41 PM
EK FLY's Avatar
so the 14 mm cant be too loose in order for the dam spring to set the pulley ?
Old Oct 7, 2011 | 04:57 PM
TouringAccord's Avatar
H-T Order of Merit
start at step 18
Old Oct 7, 2011 | 05:13 PM
EK FLY's Avatar
Originally Posted by TouringAccord
start at step 18
Old Oct 7, 2011 | 06:38 PM
brakedrum's Avatar
That's the idea.
Old Oct 8, 2011 | 07:08 AM
poorman212's Avatar
Referring to his very nice write up in the FAQ. Also might be a typo but your first post talked about turning the motor 3~4 times.....should be more like 3 teeth.
Old Oct 9, 2011 | 06:10 AM
H-T Order of Merit
lol, sorry, I mean to also include a link...
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Old Oct 9, 2011 | 07:41 PM
nus_dogg's Avatar
After those steps you listed, you're suppose to TDC the engine once again, turn the cam gear three teeths counter clockwise, loosen the tensioner adjusting nut 2/3 of a turn and retighten and you're good to go.
Old Oct 10, 2011 | 04:14 AM
H-T Order of Merit
before turning the cam gear three teeth you need to first loosen the adjusting nut.
op, if you follow the link I posted above you'll be fine.
Old Oct 10, 2011 | 01:53 PM
nus_dogg's Avatar
According to All Data here at work:
1. Disconnect the alternator terminal and the connector, then remove the engine wire harness from the cylinder head cover.
2. Remove the cylinder head cover.
3. Set the No.1 piston at TDC.
4. Loosen the adjusting nut 2/3-1 turn, then tighten it.
5. Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley, then reloosen the adjusting nut to create tension on the timing belt.
6. Tighten the adjusting nut.
7. After adjusting, retorque the crankshaft pulley 250 N.m (25.0 kg-m, 181 lb-ft).
Works everytime for me.
Old Oct 11, 2011 | 03:59 AM
H-T Order of Merit
well I'm going by the Helm Inc service manual
which has worked for me every time also
Old Oct 11, 2011 | 02:38 PM
nus_dogg's Avatar
Haha. It all works I guess. :D
Old Oct 11, 2011 | 04:47 PM
H-T Order of Merit
haha
b00st Junkie
Jul 24, 2010 07:29 PM
i-spit-hotfire
May 21, 2009 02:51 PM
god.loves.ugly
Jan 18, 2007 03:44 PM
LoudLude
Jan 31, 2006 05:21 PM
spyderracing
Sep 25, 2004 03:38 PM
