Suspension & Brakes Theory, alignment, spring rates....
"JDM" Front Camber kit: Im not tracking the car, will it work? *car picture inside*
Old Oct 7, 2011 | 01:39 PM
Arthas's Avatar
Icon7 "JDM" Front Camber kit: Im not tracking the car, will it work? *car picture inside*
Sup all.
1999 Civic Dx
FnF Type One coil overs
CTR front and rear sway bars
205/45/16 Direzza DZ101 front and Parada Spec II rear
I recently put my car back to stock exterior wise minus suspension wheels and tires. I dont really care about the car any more because I want to get a new one. Right now I have about 3.5d camber in the front and 1.5 in the rear. I just purchased some new tires so I dont want to waste them so fast.
I found a "JDM" camber kit on craigslist for $40 picked up. Will it work decently enough? I just use the car to get to work and get groceries, no hard driving. If I could get some info from people that have the kit it would be greatly appreciated.
Ignore the hipster filter, I was fooling around with the settings on my phone.
Old Oct 7, 2011 | 02:15 PM
Arthas's Avatar
Default Re: "JDM" Front Camber kit: Im not tracking the car, will it work? *car picture insid
I had BFG GeForces that lasted me about 6 months because of horrible toe. My Ventus RS-2's lasted me about a year and a half and thats because I got my alignment mid ways into having them. If I wouldve had the alignment when I purchased them I would probably still be using them today. They are amazing tires.
Point of the story, if you have altered suspension get an alignment FAST.
Old Oct 7, 2011 | 04:39 PM
98civdx's Avatar
Master Detailer
Will it work? Sure. Will it last? Not likely.
I just checked on ebay. Just what I thought it would it be.
Don't be suprised if the bushings and the ball joints fail, and if/when those bolts holding the ball joint in brake. (which happens quite often)
The like to seize. When that happens, good luck.
Also, you may run into interference issues, camber kit smashings into the shock towers.
DON'T FORGET TO GET IT ALIGNED AFTER INSTALLING!!!
Old Oct 7, 2011 | 11:11 PM
that one da's Avatar
i would just go for it, if it brakes your down a whole 40 buck...
Old Oct 8, 2011 | 02:41 AM
grumblemarc's Avatar
The Grumpiest
Horrible advice.
Don't put Chinese knock off parts on your car. Ever.
Old Oct 10, 2011 | 04:19 PM
Arthas's Avatar
Ill skip on it, thanks for the advice. I dont mind cheap parts as long as they work and get the job done. But putting cheap parts on the suspension is pushing it lol.
Also my tires lasted me 6 months with no alignment, a year and half with an alignment done when the tires got to 4/32's, so ill wait like 6 months and see how the tires look. I have lifetime alignments at Firestone so right now its good.
Old Oct 12, 2011 | 08:14 PM
untitled001's Avatar
Originally Posted by grumblemarc
Horrible advice.
Old Oct 12, 2011 | 09:05 PM
deucedeuceEK's Avatar
you would be out more than $40 and who knows what you will be doing when it does break.
dragon909boi
Honda Civic (2006 - 2015)
Apr 10, 2016 04:05 PM
9tailsfox
Jan 6, 2012 04:46 AM
memo69
May 18, 2007 07:21 PM
wardseg6
Nov 30, 2006 10:04 AM
