70-72 amp?
Old Oct 7, 2011 | 07:35 AM
Walterronny's Avatar
Default 70-72 amp?
Hi, ive been looking people use 70-75 even for 16ga piping, i dont understand how's possible because when i use 70am in my tig i can melt very fast a 10shc or flange..could be possible it has to do with 110v USA and 230V europe?
I use a Ben-royal tig 200 made in Germany 200 inverter, i got it brand new almost 2 years ago..
Old Oct 7, 2011 | 08:05 AM
SovXietday's Avatar
Default Re: 70-72 amp?
Don't know who you saw using that much amperage for 16gauge.
More like 40ish.
Old Oct 7, 2011 | 03:06 PM
FabChild's Avatar
set it to 75amps, that's what the pedal is for, to control the heat. Go do some welds and find what works for YOU. Not everyone is the same, there isn't a specific amp rating for everything. You certainly wouldn't be choosing 40 amps to weld 16ga Aluminum.
Old Oct 9, 2011 | 02:37 PM
40amps is even to hot when i try 16ga..i can melt it very fast!! not sure if it has to do with current you use in USA than i use here in Europe.
Old Oct 9, 2011 | 03:14 PM
RadekSkylark's Avatar
If you're talking about stainless steel you should be good with 40-45amps, if you use consistant heat without any kind of remote amperage control.
Old Oct 9, 2011 | 03:28 PM
i dont use pedal and yep, i use stainless steel 304 normally.
Old Oct 9, 2011 | 03:31 PM
Ok, so 38-45amps should be good, depending on you welding technique.
UncleD
Audio / Security / Video
24
Apr 24, 2006 09:06 PM
suzawa94
18
Oct 24, 2005 07:41 PM
jeremy.
Apr 30, 2005 03:05 PM
92CIVICCX
Mar 5, 2003 07:05 AM
is3oo
Mar 6, 2002 11:10 AM
