rear suspension problems
Old Oct 6, 2011 | 10:20 PM
hatmanafro's Avatar
Default rear suspension problems
okay so im sure that im due for a bushing overhaul.
when i drive my car with no weight shifting i hear a slight hum. i turn to the left therefore transferring weight to the right, the hum gets louder. but when i turn to the right, transfering weight to the left, the hum completly goes away.
anybody know what bushing that might be?.. i also notice that the rear driverside tire wears out more on the inside than the rear passenger tire
thanks guys
Old Oct 6, 2011 | 11:59 PM
GagnarTheUnruly's Avatar
Default Re: rear suspension problems
How do your RTA bushings look? I'm just guessing but maybe the hum is from a way out of alignment tire. It could be caused by bushing failures or just a desperate need to get aligned. Maybe there are other possible causes as well? It's just what occurs to me at 2:00 in the morning!
Old Oct 7, 2011 | 05:26 AM
kyden's Avatar
you sure its not a wheel bearing?
Old Oct 7, 2011 | 05:29 AM
fcm's Avatar
fcm
Old Fart
Uneven tire ware = wheel alighment problem.
Cause of alignment problem can be any number of things, the alighment shop should be able to point out the problem. 94
FOMULA91
Apr 8, 2011 01:56 PM
The Flying Dutchmen
Jul 29, 2005 07:56 AM
0ptimus prime
Feb 19, 2004 03:12 PM
solo-x
Dec 12, 2002 02:29 PM
badnan
May 29, 2002 12:21 PM
