Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power window problems...
Old Oct 6, 2011 | 04:47 PM
Syke Fu's Avatar
Icon2 Power window problems...
Hey guys I'm having some issues with my power windows in my 2004 Civic LX. I tried to let down my passenger side window from the driver side switch and heard a "pop." First thing i thought was the fuse blew. I checked it out and sure enough it was the fuse. I replaced the fuse and repeated. Same result; blown fuse. Just to make sure, i put another fuse in and this time tried to let down the window on the passenger side switch. This time no blown fuse, but the window didn't roll down either. Nothing happens at all. Anybody had any issues like this? Thanks in advance!
Old Oct 6, 2011 | 06:34 PM
joeshmo's Avatar
Default Re: Power window problems...
The pop was probably a spark as the power wire grounded somewhere. If the new fuse isn't blowing, the power wire probably moved around a bit but is no longer connected to your master switch. Likely a severed wire. Sometimes this happens around the door wire boot/tunnel thing.
Old Oct 7, 2011 | 10:41 AM
Syke Fu's Avatar
Thanks for the info. I'll try and check this weekend and see if I see any loose wiring or anything.
USA
Oct 2, 2021 03:13 PM
GhostBoy99
11
Feb 17, 2019 10:39 PM
Reme
Audio / Security / Video
Oct 6, 2010 04:08 PM
91(si)hatchey
Aug 21, 2009 04:47 PM
