FREAKNG HEADLIGHTS!!!
Old Oct 6, 2011 | 04:35 PM
Gsr-teg23's Avatar
Default FREAKNG HEADLIGHTS!!!
ok so just sold old 96dx ek just bought new 98ex and wtf is up with the headlights i keep getting screwed my driver one is pointing up higher and looks like my high beem is on when its not. same problem i had with my old one didnt bother me so much now it does!!!! lol so anyway i went to adjust them and it look like i need a key to turn the little gear thing whats up? how can i do it?????
Old Oct 6, 2011 | 05:02 PM
alphalanos's Avatar
Default Re: FREAKNG HEADLIGHTS!!!
should just be able to put a long screwdriver from the top
also check the rad support for bent
Old Oct 6, 2011 | 05:16 PM
Gsr-teg23's Avatar
hey got it thanks its on the other side of the headlights its a 10mm bolt you have to turn tight fit tho had to pull the power stearing resivouir out to get to it!
Old Oct 6, 2011 | 08:04 PM
Modell's Avatar
I believe you can do the same on both sides with a screw driver...unless the 2000 headlights are diff than 98.
honda_boy23
Mar 14, 2010 09:13 PM
cimo463
Apr 2, 2008 01:18 PM
AlanLemmerman
Sep 19, 2007 12:32 PM
myguitar
Apr 7, 2006 03:02 PM
SIcivicHATCH
Jan 13, 2005 05:57 AM
