motor makin noise ....maybe ROD?
Old Oct 5, 2002 | 12:53 PM
Charlie Moua's Avatar
Default motor makin noise ....maybe ROD?
sup guys for all that know me know that i never beat my 1993 4door auto accord.
This is my daily driver & family car...... YEasterday i heard a weird ticking noise...
-It's not the tranny or the valves ticking.
*I think it's my ROD... noise seems to be coming from driver side near the pullys
*and i only hear it mostly during idel (my exhust it already loud while driving)
****car has 164K motor is from Nippion Motors last September. I put about 15k on it so far. FELLOW ACCORD MEMBERS PLEASE HELP ME OUT
Old Oct 5, 2002 | 12:59 PM
Accord94DX's Avatar
Default Re: motor makin noise ....maybe ROD? (Charlie)
tick? or a KNOCK?
Old Oct 5, 2002 | 01:21 PM
Default Re: motor makin noise ....maybe ROD? (Accord94DX)
well it not ticking like valves or anything..... Its' sorta like a lite knock, but just a little louder than ticking valves... get what i'm saying???
Old Oct 5, 2002 | 08:21 PM
PnX-R's Avatar
Hmm. I never knew that motors could tick or knock.. It must be just your power window motor.. Get it right dude.. Motors run on electricity. Engines run on gasoline..
Old Oct 6, 2002 | 09:10 AM
Ideal's Avatar
Default Re: motor makin noise ....maybe ROD? (PnX-R)
Actually I call mine a motor half the time, what you call it depends on the person
Are you throwing a CEL?
-Jon
Old Oct 6, 2002 | 01:07 PM
p0pe's Avatar
Wow, that was very informative, you helped him out so much
Old Oct 6, 2002 | 03:56 PM
Peter Yang......WHF are you talking or refering to???? No it't not the PW.
Old Oct 6, 2002 | 04:46 PM
SOHCArchangel's Avatar
does it go
'clank, clank, c-clank, clank' ?
Old Oct 6, 2002 | 09:09 PM
snoop_bealybob's Avatar
Default Re: motor makin noise ....maybe ROD? (SOHCArchangel)
How loud is the noise? If it's clicking like a pen, I'd check the plugs. Is there a lack of power? Or poor idle? I've seen plugs come loose a bit and make a clicking noise. I've also seen spark plug wires and direct ignition coil ends come off the spark plug a bit and make a clacking/clicking/ticking noise.
Have you checked your oil level? What is the weight that is in it now? Does it corespond to the type of weather that is in your area still?
Is the noise on start up or does it continue while you drive? Are you sure the noise is coming from the engine (MOTOR)? Have you put a scope to it and really listened? Or is it just in that general area?
Does the car shake at all when it makes this noise? Maybe you could check the motor mounts and see if the are torqued correctly?
Is there any accesory mounts that may be loose causing a noise ?
Can you tell me a little more about the car? Did you have it rebuilt you said? Can you take it in? Still under warranty?
[Modified by snoop_bealybob, 6:13 AM 10/7/2002]
Wannabe JDM
Jun 1, 2013 08:30 PM
acracer2008
Aug 2, 2010 05:35 AM
DOHCDA
Apr 15, 2008 11:04 AM
Ilouisell
10
Aug 22, 2003 04:51 AM
