OH: 2000 Acura Integra Type R Procharged
$15,000 obo
Will trade for DD plus cash
Phoenix Yellow
~136,000
I have owned this car since 34,000 miles. The majority of the miles on this car are highway. It has been up to Lake Superior and down to Kentucky. Over to Illinois and back to West Virginia. I daily drive this car year round. I have no issue jumping in it for a long distance trip or to the corner store. All the work with the exception of tuning was done by myself. I am an ASE Master Certified Technician. The car runs low 13's high 12's in the quarter. Top speed is approx. 150 mph. Any questions, please feel free to contact me.
ATI Procharger C-1A (http://www.procharger.com/pdf/appGuide.pdf page 46 1HB202-SCI)
Precision Turbo & Engine 440 cc Injectors (http://www.precisionturbo.net/air-fu...t-Injectors/40 )
AEM Fuel Pressure Regulator - Blue (http://www.aemelectronics.com/adjust...-1994-2001-291 )
Accel 300+ Digital Ignition (http://store.prestoliteperformance.c...-01-w-tec.html )
Accel Wires (http://store.prestoliteperformance.c...-red-7015.html )
NGK Iridium Plugs (BKR7EIX-11 http://www.ngksparkplugs.com/product.../iridiumix.asp )
MSD Remote Coil Cap and 8.8mm Coil Wire (http://www.msdignition.com/Products/...GSR_94-01.aspx )
Hondata S300 (http://hondata.com/s300.html Tuned by IPSMotorsports Eric Harget)
SlowMotion Triple O-Ring Cam Seal (http://shop.slowmotionmotorsports.com/ )
Window Weld Motor and Transmission Mounts
AEM Underdrive Pulleys
JEG’s Fuel Pressure Gauge (http://www.jegs.com/i/JEGS+Performan...41015/10002/-1 )
Hytech Replica Header (SlowMotion)
Cat Delete
KTeller 3” SS Cat Back Exhaust (http://store.kteller.com/kteller/kte.../i-402955.aspx )
Dynomax Muffler
B&M Short Shifter (http://www.bmracing.com/PRODUCTS/Acu...-Acura-Integra )
Brembo Slotted Rotors (http://www.jdmhub.com/index.php?rout...44_13660_14893 )
SS Braided Brake Hose (http://www.amazon.com/Goodridge-Stai.../dp/B000IJBLGK )
Hawk HPS Pads (http://www.hawkperformance.com/ )
ATE Blue Brake Fluid (http://www.tirerack.com/brakes/acces...tail.jsp?ID=21 )
AMSOIL (http://www.amsoil.com/storefront/azo.aspx )
Royal Purple Transmission Fluid (http://www.royalpurple.com/manual-tr...ion-fluid.html )
Royal Purple Power Steering Fluid (http://www.royalpurple.com/power-steering-fluid.html )
Redline Water Wetter (http://www.redlineoil.com/Products.aspx?pcid=10 )
Mugen Radiator Cap (http://www.kingmotorsports.com/p-38-...iator-cap.aspx )
Mugen Thermostat (http://www.kingmotorsports.com/p-43-...hermostat.aspx )
Mugen Fan Switch (http://www.kingmotorsports.com/p-145...an-switch.aspx )
Mugen Pedals (http://www.kingmotorsports.com/p-225...al-kit-mt.aspx )
JDM Recaro Driver Seat (http://passwordjdm.com/JDM-DC2-ITR-R...-P1134C90.aspx )
JDM Armrest Eliminator (http://passwordjdm.com/JDM-DC-ITR-Ar...1069C1685.aspx )
JDM Red Stitch Shift Boot (http://passwordjdm.com/JDM-DC-ITR-Sh...1302C1685.aspx )
Vector 985 Hardwired (http://www.beltronics.com/manuals/v985manual.pdf )
Alpine Radio CDA-9883 (http://vault.alpine-usa.com/products...-9883%20OM.PDF )
I-Pod Integration Cable
Hondata Cable
Alpine Type R Component Speakers (http://shop.alpine-usa.com/products/...8.0.0.0?pp=12& )
Alpine Type R Speakers (http://shop.alpine-usa.com/products/...8.0.0.0?pp=12& )
Pioneer Spare Tire Subwoofer (TSWX-50 No longer produced)
All sound deadening material removed
S2000 Antenna Conversion
Crow 5-point Harness (Both fronts, only lap belt is installed http://www.parts123.com/parts123/yb....ort~1~cadeikca )
Cabin Filter (Not a factory option)
Red Interior Lights
HID 55w High and 35w Low Beams (http://www.ddmtuning.com/Products/DD...ast-35W-or-55W )
Direzza Star Spec Tires 205/50r15 (http://www.dunloptires.com/catalog/d...1StarSpec.html )
Vacuum/Boost Gauge (http://www.autometer.com/cat_gaugede...id=3149&sid=11 )
Air/Fuel Ratio Gauge (http://www.autometer.com/cat_gaugede...id=3083&sid=11 )
PLX Wideband (http://www.plxdevices.com/Installati...UsersGuide.pdf )
Dual Gauge Instrument Cluster (http://www.summitracing.com/parts/ATM-20011/ )
Hondata Intake Gasket (http://hondata.com/heatshieldgasket.html )
Throttle Body Coolant Bypass
Not Installed
Air/Fuel Ratio Gauge (http://www.autometer.com/cat_gaugede...gid=2484&sid=2 )
Quad Pod (http://www.quad-pod.com/quad-pod.html )
Clock Pod (http://www.quad-pod.com/clock-pod_select.html )
Type R Driver Seat
Type R Center Console
Type R FULL Exhaust (Header to tip)
Type R ECU
Type R Injectors
Type R Distributor Cap
Type R Ignition Coil
Type R Speakers
Raybrig Foglights (Factory)
Alpine Radio CDM-9801 (Dealer Option) (http://vault.alpine-usa.com/products...20CDM-9801.PDF )
Factory Power Antenna (doesn’t retract)
Type R Intake
Extras
Supercharger Oil
AMSOIL Transmission Fluid
Oil Filters
Factory Jack
Visors
Valve Cover
Steel Wheels
The interior pictures are older. I can get pictures of anything needed.
T.J. 937-243-4521
Phoenix Yellow
~136,000
Cat Delete
Dynomax Muffler
Hondata Cable
Red Interior Lights
Not Installed
Type R Driver Seat
Type R ECU
Type R Injectors
Type R Speakers
Type R Intake
Extras
Supercharger Oil
Oil Filters
Factory Jack
Visors
Valve Cover
Steel Wheels
T.J. 937-243-4521
