Z6 in 00 civic dx HELP!!
Old Oct 5, 2011 | 09:17 PM
LiL JoN's Avatar
Default Z6 in 00 civic dx HELP!!
I have a 00 civic dx has a z6 in it ..did the 3 to 2 wire iacv and the CKF bypass trick and has a rywire dizzy converstion as of now im running a 00 civic si ecu starts but boggs and dies when i give it gas ..... WHAT COULD IT BE ???????? HELLPPPP
Old Oct 5, 2011 | 09:39 PM
92blackegmtx's Avatar
Default Re: Z6 in 00 civic dx HELP!!
00 si ecu is for a b16. that ecu is not designed for a single cam. Get a y8 ecu and you'll be right as rain.
Old Oct 5, 2011 | 09:40 PM
LiL JoN's Avatar
i know that its for a b16 but shouldnt it still run the car?
Wrona's Avatar
ur running a b16a2 ecu the P2T why the hell are you running that with the D16Z6 why are you not running the P28 OBDI ECU
you are running a OBD2B ecu on a OBDI engine...
get the right ecu
it starts the car and boggs down doesnt it it runs it but it runs like sh(t cause its the wrong ECU
Old Oct 5, 2011 | 10:22 PM
LiL JoN's Avatar
Old Oct 6, 2011 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
You definitely have check engine lights, pull them and post them. The Z6 has no knock sensor. How did you wire the secondary O2?
Old Oct 6, 2011 | 08:04 AM
LiL JoN's Avatar
throwing the vtec system malfunction since vtec isnt wired yet and used the stock y7 header that has the 2 o2 on the header.....
Old Oct 6, 2011 | 08:11 AM
grumblemarc's Avatar
The Grumpiest
I'm sorry but was the question ever answered as to why a dual cam ECU is trying to run a single cam engine?
Old Oct 6, 2011 | 10:11 AM
LiL JoN's Avatar
only ecu i have and the stock 99 dx one
Old Oct 6, 2011 | 10:41 AM
The Grumpiest
More than likely, THAT is your problem. That and the ECU is OBD2B and the engine is OBD1 as was stated.
Old Oct 6, 2011 | 01:16 PM
wmac's Avatar
yes, you need an obd2b to obd1 conversion harness and a p28.
also 2 wire IACV conversion, and wire teh vtec if you're using your dx engine harness.
also, what injectors did you use. y7 injectors are 190cc but p28 will want 240cc injectors.
you can use obd2 240cc(y8) or splice the clips for the d16z6 (obd1) injectors.
i put a z6 in my 97(obd2a) dx.
Old Oct 6, 2011 | 05:06 PM
LiL JoN's Avatar
tried the stock dx ecu stays on till u give it alot of gas boggs till it turns off... help
Old Oct 6, 2011 | 05:10 PM
The Grumpiest
Are you NOT listening? You need a P28. Get one.
Chris404
Jan 4, 2020 11:54 AM
OneTyteEK9
Apr 27, 2006 09:13 AM
OUTKAST_R
Jan 11, 2005 03:15 PM
