Heater Control Dash Problem Please Help
Old Oct 5, 2011 | 06:21 PM
pmp's Avatar
pmp
Default Heater Control Dash Problem Please Help
http://cgi.ebay.com/ebaymotors/HONDA...item5ae2c76d8d
the hot and cold switch on this. I was moving the switch from cold to hot and it like got stuck and it felt like somthin broke now only the cold side works. when i put it on hot no heat comes out. Would this be maybe the cable disconnected. Please help. LEt me know if this is an easy fix or what. THanks
Also the lights in this part keep goin out and i hit it and usually it comes back on how would i change the bulbs?
Thanks
Old Oct 5, 2011 | 06:32 PM
Former User's Avatar
Default Re: Heater Control Dash Problem Please Help
Yes, definitely check whether the cable has come loose near the left foot of a front passenger.
Old Oct 5, 2011 | 06:34 PM
pmp's Avatar
pmp
do you have a diagram to remove this center piece. Can i just re attach teh cable or somthin?
Old Oct 5, 2011 | 06:37 PM
Old Oct 5, 2011 | 06:42 PM
pmp's Avatar
pmp
is this my problem?
Old Oct 5, 2011 | 06:44 PM
In diagram, did you check the cabin side or engine firewall side?
Old Oct 5, 2011 | 06:46 PM
pmp's Avatar
pmp
ye its on the heater control valve. i just replaced the valve like within a month ago it started leaking.
Old Oct 5, 2011 | 06:47 PM
pmp's Avatar
pmp
i went to move the hot/cold **** to hot and moved it back and it got real tight now its really loose. it only blows cool air now no heat. and winter is around the cornor.
Old Oct 5, 2011 | 06:48 PM
Read my posts carefully. Did you check the cable on the cabin side. See step 2 in diagram.
Old Oct 5, 2011 | 06:59 PM
pmp's Avatar
pmp
no i didnt i only checked the firewall side. How do i get to the cable?
Old Oct 5, 2011 | 07:06 PM
I've already posted everything you need to know.
Old Oct 5, 2011 | 07:07 PM
pmp's Avatar
pmp
ok, all it says is from under the dash how do i get to the cable? do i have to remove stuff?
Old Oct 5, 2011 | 07:08 PM
You fail to read all that I posted. READ for comprehension.
Old Oct 5, 2011 | 07:15 PM
pmp's Avatar
pmp
sorry i see the cable lemme try this
Old Oct 5, 2011 | 07:31 PM
pmp's Avatar
pmp
what do i do on step 2 do i disconnect the cable?
Old Oct 5, 2011 | 07:34 PM
Does the air mix control arm move when you slide the temp lever in the heater control panel right and left?
Old Oct 5, 2011 | 07:39 PM
pmp's Avatar
pmp
idk how to do this forget it ill have to pay someone
Old Oct 5, 2011 | 07:41 PM
pmp's Avatar
pmp
no it doesnt move
Old Oct 5, 2011 | 07:43 PM
Grab hold of the cable, pull it toward the firewall to create tension, and move the temp lever back and forth. Do you feel the cable move at all?
Old Oct 5, 2011 | 07:48 PM
pmp's Avatar
pmp
ye i feel the cable move
Old Oct 5, 2011 | 07:49 PM
pmp's Avatar
pmp
theres like too much cable when i move the switch back and forth i dont even see where the cable is attached to move at all
Old Oct 5, 2011 | 07:52 PM
Is the cable correctly attached in step 2. Post a picture.
Old Oct 5, 2011 | 07:54 PM
pmp's Avatar
pmp
i think so. its on the clamp and hooked on that thing
Old Oct 5, 2011 | 08:01 PM
Remove the heater control panel and inspect it where the cable connects.
Old Oct 5, 2011 | 08:04 PM
pmp's Avatar
pmp
the cable is connected to the hot/cold switch. i can feel the cable when i move the hot/cold sitch back and forth
