Do I have to take factory alarm out to replace with aftermarket alarm?
Old Oct 5, 2011 | 01:11 PM
97dssi's Avatar
Default Do I have to take factory alarm out to replace with aftermarket alarm?
Hello I have a question about factory car alarm in my 1997 Honda Del sol. I’m buying an aftermarket alarm to install in my Del sol. Do I have to take the factory car alarm out or leave it in and just hook up the aftermarket car alarm? If I have to take it out and will aftermarket alarm work without factory alarm? Thanks.
Old Oct 5, 2011 | 10:39 PM
97dssi's Avatar
Default Re: Do I have to take factory alarm out to replace with aftermarket alarm?
Bump
Old Oct 6, 2011 | 04:58 AM
tlarimer's Avatar
If the delsol alarm is integrated into the factory wiring like the EK Civic's, you really cant remove it without major headaches
Old Oct 6, 2011 | 07:07 AM
motegicivic's Avatar
Are you sure it is a factory alarm?
I know the 96-98 civic had factory (accessory option) alarms integrated into the radio and was prewired.
In your case I would just make sure it is not armed, and then just install your new alarm.
Old Oct 6, 2011 | 07:16 AM
phat00civic's Avatar
I believe you piggy back off that harness and then it is disabled but I can be way off. Did you google it?
Old Oct 6, 2011 | 08:29 AM
97dssi's Avatar
Well its factory alarm so I’m sure it’s integrated into the factory wiring.
Yes I’m sure its factory alarm. My Del Sol radio doesn’t have the alarm integrated into radio. I know what alarm looks like on the ek but I don't see any on my Del Sol. unless ek have alarm built-in in the radio? My factory alarm is under my driver seat.
Yes I did Google everything I could try to find but nothing good information about factory alarm with aftermarket alarm... that's why I am asking here.
Old Oct 6, 2011 | 09:37 AM
This is a great write up I use:
http://causeforalarm.thecarthing.com...vic/index.html
I also found this:
http://www.autotoys.com/New_Tech/DIY...m/civalarm.htm
DCFIVER
Acura TL, RL & ZDX
Mar 28, 2011 06:07 AM
GoLowDrew
Audio / Security / Video
May 30, 2006 03:37 PM
Bklyn TSi
Jan 22, 2004 08:33 AM
SamC
11
Dec 14, 2001 10:56 PM
