Gsr timing issue...
Old Oct 5, 2011 | 11:41 AM
sc34dc4's Avatar
Default Gsr timing issue...
Okay so the other day my car shuts off. After messing with it I figure out it jumped time. So I put it back in time and start it up. Idles rough and revs up rough. I figured bent valve/s. It was cold and rainy so I called it a day. Today I go back over the timing and reset it all just to be 100% it was all lined up. Start the car and it idles fine and revs up fine. So I was relieved at this point cause I could rule out bent valve/s. I drive it around the block and then down the road and back. Running it up to about 5K. All is well it's building boost and pulling hard so I'm happy. Pull in the driveway and turn it off. I pull the valve cover back off to install the upper timing cover. I lay down some rtv,put the valve cover back on and button everything up. I go start the car to go drive around feeling accomplished that it's running right and again it's idling rough now. Seriously 10 minutes after taking it for a test drive and it was running ok. Any ideas as to what's going on?
Old Oct 9, 2011 | 06:38 PM
streetplayas's Avatar
Default Re: Gsr timing issue...
check spark plugs arent fouled and posably ur distributor and if all do a leak down especially if ur gonna be taking out the spark plugs it will give you an indication on whats going on
Old Oct 9, 2011 | 08:19 PM
sc34dc4's Avatar
Thanks for the reply. I got it sorted out now. Just needed a new set of plugs.
93lsDA
Apr 13, 2010 12:34 PM
The_Honda_Guy
13
Apr 20, 2009 07:58 PM
SOHC-Tech
Nov 13, 2006 04:23 PM
92B20GSR
Nov 13, 2003 12:32 PM
