97 accord backfiring problems.....?
Old Oct 5, 2011 | 06:43 AM
yovani moreno's Avatar
Default 97 accord backfiring problems.....?
When ever the engine is cold, i turn the car on and when i step on the gas to ride it hesitates and if i put more pressure on the gas it makes explosion noise. What can be some possible causes for this? i juts change the spark plugs, the wirering, and also the rotor in the distributer and the cap. i also changed the fuel pump, the castalist coverter.
Old Oct 5, 2011 | 08:40 AM
CDelgado220's Avatar
Default Re: 97 accord backfiring problems.....?
Check your spark plug wells. Sounds like oil filled wells. You might just need a valve cover gasket change and maybe the lower seals as well below the rocker assembly.
Old Oct 5, 2011 | 04:50 PM
rival12's Avatar
Have you checked Oxygen Sensor(s)?
Old Oct 5, 2011 | 09:00 PM
holmesnmanny's Avatar
If it's happening before the engine warms up the oxygen sensor can't be a factor in the problem since it hasn't heated up yet.
I would think maybe leaking head gasket it letting coolant into the cylinder overnight and is backfiring as it burns off. Has your car overheated recently ? How's the car running after it warms up ? Any loss of power ?
Old Oct 5, 2011 | 10:36 PM
MAD_MIKE's Avatar
MM Gruppe B
Did it misfire before you replaced the sparkplugs, wires, cap and rotor?
Did you verify that the timing is correct?
papp-fox
Jun 30, 2017 04:07 PM
Eg92h22Ek97
May 17, 2017 05:15 AM
vietdragontekx
Jan 12, 2015 04:48 PM
civic402lx
Apr 20, 2010 07:31 AM
johnnycat022
Sep 27, 2004 04:53 PM
