H22 Help
Old Oct 5, 2011 | 06:29 AM
Bc1r6x's Avatar
Icon2 H22 Help
I have a 92 prelude with an h22a4 running OBD1 and have been running on the H23 ecu and injectors up until yesterday when I tried installing the saturated 370cc RC injectors and a P13 ECU. It was running much richer than I expected so I put the resistor box back in line with the injectors and changed the plugs because they were fouled out so basically I put it back to the way it was before when it was running fine. I still have a real bad misfire and its in limp mode/It won't rev over 3,500rpm. I was thinking a compression test is a good start any other ideas.
Old Oct 5, 2011 | 06:49 AM
Acidcrakker's Avatar
Default Re: H22 Help
I always forget what is saturated injectors and what is non saturated.
If your running injectors without the resistor box did you plug the yel/blk wire into the 4 injector wires that ran to the resistor box?
Also your running an obd2 engine on an obd 1 ecu, Im assuming that you converted it over to obd1 or I miss read that?
Old Oct 5, 2011 | 07:31 AM
typemismatch's Avatar
Honda owns me
Saturated are high impedance, pull the resistor box and mod the wiring for it.
Old Oct 6, 2011 | 05:54 AM
flyrod's Avatar
I would start with figuring out the ecu issue. For example, is it throwing any codes?
H22 SL33P3R
Nov 4, 2014 10:52 AM
more3688
Mar 10, 2010 02:57 PM
raidacaipo
Feb 15, 2009 01:33 AM
4thgenhtch
Jan 31, 2006 12:44 PM
e jay one
Aug 6, 2005 02:48 PM
