88 ef civic ls/vtec starting problems?
Old Oct 5, 2011 | 12:03 AM
tihs-yolloh's Avatar
Default 88 ef civic ls/vtec starting problems?
figured it out thanks.
Old Oct 5, 2011 | 03:13 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 88 ef civic ls/vtec starting problems?
That's great but...
1.) Are you running the same tune as before?
2.) Is the engine specifications the SAME as before?
3.) Did you put new plugs in/check for WEAK spark?
4.) What is your cold start fuel trim like?
5.) Better yet - what base map are you using?
Old Oct 5, 2011 | 05:16 PM
I bought the ecu new and i built this motor im just trying to get to idle and be able to baby it around so i can break it in. im running ngk vpower there new so imagine its not from them. i belive the injectors arent pulsing?
90SiHatchy
Aug 4, 2011 04:47 PM
JDMmadness
Feb 18, 2010 01:43 PM
isaygo
Jan 9, 2007 01:05 PM
supracrx
Oct 29, 2006 09:58 PM
