Alternator B series?!
Old Oct 4, 2011 | 10:04 PM
ddysgrl's Avatar
Icon2 Alternator B series?!
need help knowing the correct alternator for a b16a. any suggestions? help relating to this post pls
Old Oct 5, 2011 | 03:10 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Alternator B series?!
Any B-series will work... what exactly is it you are looking for?
Old Oct 5, 2011 | 10:51 AM
ddysgrl's Avatar
some peps say d series or b17...blah blah. i need help findin the b series for my b16a. and i the belt too.
Old Oct 5, 2011 | 04:58 PM
hiiimseth's Avatar
like he said b series.. all b series parts are basically interchangeable
Old Oct 5, 2011 | 06:23 PM
crx_si-r's Avatar
all b-series alternators are interchangeable. however i do find the B17 listed parts are cheaper at auto parts stores than the ones listed for B18a and B18c. my .02 i buy them for a b17a1.
if you truly want one for a b16 then just buy one from a 93-95 Del Sol Vtec model.
Old Oct 6, 2011 | 01:36 PM
ddysgrl's Avatar
aight thanks much!
Old Oct 6, 2011 | 09:58 PM
ddysgrl's Avatar
what bout aperture? i have stereo system. will the 94 del sol vtec hold up?
Old Oct 6, 2011 | 10:16 PM
gringo7718's Avatar
EDIT:
All B-series obd-0 & obd-1 alternators are the same, and are plug and play.
obd-2 alternators require a different plug
Alternator Belt - #040300 or #040305
Old Oct 6, 2011 | 10:22 PM
crx_si-r's Avatar
Ummmmm. Who/what info are you saying is incorrect? All 90-95 b18a/b alternators use the same plugs. All 92-93 b17a1 alternators have the same plug. All 94-95 b18c1 alternators have the same plugs. And all obd1 b16a3's use thesame alternators.
And all listed alternators have the same ribbed pulley on them.
All amperage ratings are between 70-85 amps. Basing the Mp rating off memory, so numbers may be wrong. But they are interchangeable.
Old Oct 6, 2011 | 10:30 PM
gringo7718's Avatar
Thanks for clearing that up crx si-r. You are correct.
Old Oct 6, 2011 | 10:39 PM
crx_si-r's Avatar
No rewiring required on any 90-95 b series alternator. They are wired up exactly the same. The 96-01 b-series alternates will also work, they just require you to rewire and add in a square plug as opposed to 88-95 alternators that use a bigger round plug.
Old Oct 6, 2011 | 10:48 PM
ddysgrl's Avatar
damn i dnt wana change any wiring its a frikin hassel
whats the diffrence with obd 0 and 1?
del sol vtec or acura integra?
Old Oct 7, 2011 | 04:28 AM
DO IT ON ALL FOURS
What are you talking about? The '88-95 alternators have the same plugs...
mayfly
Jul 22, 2010 01:09 PM
1getbored
Feb 14, 2008 11:16 PM
4door93civic
Northwest (Sales)
Oct 20, 2007 07:43 PM
allanonjj
Nov 7, 2005 01:58 PM
Soled Out
Sep 15, 2003 06:58 PM
