1993 Honda civic dx white smoke
Old Oct 4, 2011 | 07:48 PM
bri224's Avatar
Default 1993 Honda civic dx white smoke
I have a 1993 Honda Civic DX D15B7 and auto transmission and there is a lot of white smoke coming out of the exhaust. I just replaced the head gasket when I pulled the head off because I needed to replace two exhaust valves in one cylinder because one was chipped i just changed the oil and the coolant when i replaced the head gasket. I am not sure what is causing it to smoke.
Old Oct 4, 2011 | 07:54 PM
Go_Race_Your_Self's Avatar
Two Piece
Default Re: 1993 Honda civic dx white smoke
Did you torque the head to spec and in sequence?
Kev
Old Oct 4, 2011 | 08:31 PM
701EGhatch's Avatar
you could have warped your head
Old Oct 4, 2011 | 09:33 PM
street_racer_271's Avatar
coolant is getting into your combustion chamber, re-torque head, or like stated above, it could be warped, from possibly over heating
Old Oct 4, 2011 | 09:34 PM
Two Piece
Also, did you allow the motor to cool down before taking the head bolts out?
Kev
Old Oct 4, 2011 | 10:09 PM
701EGhatch's Avatar
yea u do know u have to do a pre set like 26 lbs then go back and do final tq like 37lbs or what ever hondas are im not a big honda motor master! yet?? ha
Old Oct 4, 2011 | 10:44 PM
OmgDelSol's Avatar
Hmm...I'm having a similar problem with my EG2. I believe my problem is it has 260,xxx miles on it. Does yours smell pretty strong?
Old Oct 4, 2011 | 11:03 PM
Texas4door's Avatar
Time to do it again!
Old Oct 5, 2011 | 07:31 AM
Two Piece
hn94civic_sm6-055a
Old Oct 5, 2011 | 01:10 PM
bri224's Avatar
I torqued the head in sequence and to spec in the two stage pattern following Michal on demand and I replaced the head bolts when i put it all back together. I am going to try to re-torque the head. Is it possible that the cat is saturated with coolant and is burning it off or could it be sucking transmission fluid into a vacuum line some how and burring that. I had some of the valves resat and the machinist milled the head flat when i had it out so I dont think it is warped.
lifesastruggle
Engine Management and Tuning
Feb 15, 2017 03:22 AM
JDMBukLau
Nov 30, 2012 07:30 PM
derek18105
11
Nov 25, 2012 04:19 PM
hondarondon9296
Oct 11, 2009 12:38 PM
crxhftosi
Feb 9, 2005 06:14 AM
