b20 ef hatch problem
Old Oct 4, 2011 | 05:16 PM
ej1252's Avatar
Default b20 ef hatch problem
my ef has a problem. when i try to turn it on it idles low like 400-500 and it sounds like its gonna die when it stays on. when i throttle it, it shuts off instantly.
what can the problem be?
i change rotor/cap & coil
hondata s300 P28 w/ b20 base map
converted to obd1 (injectors, dizzy, alterntor)
injectors are wired straight to the ecu
if you need anymore info LMK
Old Oct 4, 2011 | 06:39 PM
ef_cowboy's Avatar
Default Re: b20 ef hatch problem
try adjusting the idle screw and if that only las t a day then check the health of the engine(compresion and leakdown test)
Old Oct 5, 2011 | 08:11 AM
CanadianEF9's Avatar
Throttle senors----flip the out side wires around
jakeosbo
May 9, 2017 06:10 AM
allmotorCRX.
13
Jun 12, 2011 06:46 PM
jdmda_1.7a
Aug 30, 2010 09:46 PM
