b20 ef hatch problem
my ef has a problem. when i try to turn it on it idles low like 400-500 and it sounds like its gonna die when it stays on. when i throttle it, it shuts off instantly.
what can the problem be? i change rotor/cap & coil hondata s300 P28 w/ b20 base map converted to obd1 (injectors, dizzy, alterntor) injectors are wired straight to the ecu if you need anymore info LMK |
Re: b20 ef hatch problem
try adjusting the idle screw and if that only las t a day then check the health of the engine(compresion and leakdown test)
Throttle senors----flip the out side wires around
