Turbo crx wont start
http://www.youtube.com/watch?v=TdoUCIx6p5w After this video it jump started i took off the = cable and it said running so the alternator is good right.?????????????????
I had some funky stuff going on with my car when my alt died a couple weeks ago...blinker would make the tach jump all over and weird stuff like that. Dunno bout your door locks...i would think its a wiring issue or something, but couldn't say for sure, but if the car is running and all your lights are as bright as they should be at idle, then your alt should be ok, that was always the sign i got when mine have gone out.
IMO
Either the battery ground or a stuck starter.
(Get some of that 0 guage wire, strip both ends touch both starter connections)
one side of the wire to the 12mm bolt..... the other side of the wire to the thin signal wire.
BarnFindCRX
Jun 2, 2019 07:36 AM
HaRd KoRe CRXtasy
Sep 9, 2004 09:25 PM
