Trying to source 1/4" ATF or P/S hose
Old Oct 4, 2011 | 08:57 AM
oneprblmcat's Avatar
Default Trying to source 1/4" ATF or P/S hose
I have one P/S return hose that is obsolete. Anyone know where I can get 1/4" ATF or P/S hose line? Engine searches are nil and parts stores try to sell me fuel or vacuum hose.
Thanks
Old Oct 4, 2011 | 11:31 AM
redbull-1's Avatar
Default Re: Trying to source 1/4" ATF or P/S hose
It depends on where you live. 1/4" may be tough. Out in Northern Ca., Vic Hubbard stocks an assortment of hoses that other shops don't have, don't know if they may have it though. There was another shop I use to go to a long time ago; but, they changed ownership and the stock they carried.
Old Oct 5, 2011 | 02:54 PM
Lost Again's Avatar
Try carquest, last time I meed some trans cooler hose they had it, told them how many feet I needed...they cut off the roll and I was good to go. They sell gates hose, so you can go to gates' website and find the part number...1/4 maybe hard, 5/16 is part number 27058
Old Oct 5, 2011 | 04:24 PM
rival12's Avatar
Power Steering Hose? Check local Wrecker/Junkyard they are plentiful around me. About 400$ new from Honda.
Old Oct 6, 2011 | 05:17 PM
It's the small power steering return hose that's near the power steering sensor for the transmission. It's about 6" long and looks like 1/4" ID (or maybe smaller) hose with a couple small spring clamps. It's that special ATF / Steering Fluid hose Honda has but this particular hose is discontinued and I count on this car way too much to put another piece of used hose. It's just brittle right now and not leaking but I've replaced every other hose in this thing except that.
Kennethbtaden
May 14, 2017 03:05 PM
rnacion
Mar 24, 2014 08:47 AM
simbabeat
Jan 19, 2014 10:53 PM
sgull
Sep 23, 2013 05:27 PM
Apex1972
Jan 27, 2008 02:37 PM
