92 Civic dash lights not working
Old Oct 4, 2011 | 08:18 AM
717DC's Avatar
Default 92 Civic dash lights not working
Hello I recently picked up a 92 civic and it has a frustrating issue of the dash lights not working. I replaced the dimmer switch and the headlight switch both with no luck. I have researched this topic and only found it to be three possibilities the headlight switch, the dimmer and the dash wiring. I have a friend with a dash harness that came from a car with working dash lights, so I was going to pick it up and replace mine with that. But before I do is there anyone who think it might be something else? Also previous owner said they went out shortly after best buy installed the radio.
Old Oct 4, 2011 | 08:23 AM
Former User's Avatar
Default Re: Dash light issue
Is the problem both the cluster lights and dash lights (heater control panel)?
Have you checked for a blown fuse 19?
Old Oct 4, 2011 | 08:42 AM
717DC's Avatar
Yes, the clock and radio work its just the cluster and climate control. And I'm currently at work, so I can't see the car to see what fuse 19 is. If its the fuse that's for the license plate lights and the dash lights, I have checked it.
Old Oct 4, 2011 | 08:59 AM
Default Re: 92 Civic dash lights not working
Do the clock and radio lights brighten and dim when the dimmer switch is dialed to different positions?
Old Oct 4, 2011 | 10:16 AM
717DC's Avatar
No they do not.
Old Oct 4, 2011 | 10:19 AM
Unplug the dimmer switch. Does the black wire have continuity to body ground? With the parking lights on, does the Red/Blk wire have battery voltage to body ground?
Old Oct 4, 2011 | 05:08 PM
717DC's Avatar
I will check that on friday when im off. I forgot to mention that certain times i use the turn signal the clock will flicker and get bright for a split second. Any ideas?
Old Oct 4, 2011 | 05:43 PM
Raven_1's Avatar
My dash and climate control cluster lights some times flicker then the climate control does not light back up but the dash lights come back on. Keep me posted on any progress. I rechecked wiring and fuses with no luck.
Old Oct 8, 2011 | 03:27 AM
717DC's Avatar
Just checked all the wires they are all good but when i pulled off the switch i found this.
It appears that the ground wire was burnt up at one point in time. Is it a possibility there was a short and 2 wires melted together in the dash harness at one point?
Old Oct 8, 2011 | 05:49 AM
virgineg6's Avatar
Definite possibility, but the others wires dont look damaged (from what i can see anyway) and that is a ground wire so shorting to gnd at that burned spot wouldnt cause any problems. Does the defroster switch light up?
Old Oct 8, 2011 | 05:50 AM
virgineg6's Avatar
Hazard light, light up?
Old Oct 8, 2011 | 05:57 AM
Get a multimeter and do this:
Also jump the red wire to the black wire in the connector - do the cluster lights now work?
Old Oct 8, 2011 | 08:51 AM
717DC's Avatar
YESS!!! Now i have lights after jumping the black and red wire.
Old Oct 8, 2011 | 09:55 AM
If the Red/Black wire has voltage, then replacing the dimmer switch should fix the problem.
The radio and clock back lights must be wired to a different circuit, which strays from stock. You may want to bring that wiring back to stock.
Old Oct 8, 2011 | 09:59 AM
717DC's Avatar
The clock, and gauges work but i still dont have climate control lights.
Old Oct 8, 2011 | 10:03 AM
Do the radio and clock have back lights. Do they work.
Check the Red and Red/Blk wires behind the climate control.
Old Oct 8, 2011 | 10:42 AM
virgineg6's Avatar
The lights burn out on the climate control, check for power at the climate control. If that checks good the the bulbs are burned.
Old Nov 26, 2011 | 07:08 PM
DarkEG's Avatar
I have an issue with my cluster backlight not working. My climate control lights are working though. I jumped the red and black wires and still only my climate control lights are working, i've also checked out the bulbs behind the cluster and they look fine. Any thoughts?
Old Nov 27, 2011 | 09:29 AM
sohc-monster's Avatar
I have a similar issue with my climate control lights just replaced the bulbs and still nothing all other lights work fine any suggestions?
Old Nov 27, 2011 | 09:40 AM
Using a multimeter, check whether voltage reaches the red wire and Red/Blk wire in the cluster connector.
Old May 8, 2014 | 05:24 PM
@imraging's Avatar
I'm having the same problem. and i shorted out the red wire thats on the left with the black in the middle and it blew the fuse. I replaced the fuse and still the lights dont work.
Old May 8, 2014 | 05:29 PM
Start here --> Check for a short in the Red/Blk wire at the rear of the radio.
Old May 8, 2014 | 05:36 PM
@imraging's Avatar
I got a aftermarket radio, and no its not shorted out.
Old May 8, 2014 | 05:37 PM
How do you know?
Old May 8, 2014 | 05:40 PM
@imraging's Avatar
How do you know?
Because i checked..............
