Turbo Identification?
Old Oct 2, 2011 | 08:54 PM
alexanderlewolf's Avatar
Icon2 Turbo Identification?
So I am in the middle of cleaning and rebuilding an old greddy turbo kit for my d16z6 and I'm confused. It came with 2 turbo's one of which I am pretty sure is a greddy 15g but the other one is not something I can find by searching. I was actually desperate enough to even search the "DSM FORUMS". As helpful as the info there was I still know zilch. So after three and a half hours of searching with google giving me terrible results, I have to ask.
What are these turbos? Am I correct in stating one is a greddy 15g? I know I'm new here but I am really at a dead end.
THANK YOU IN ADVANCE!
Old Oct 3, 2011 | 05:48 AM
TheShodan's Avatar
Moderator
Default Re: Turbo Identification?
You need to measure the inducer and exducers of the compressor. The housing part numbers just state like the inscription that its a TD04. The GReddy uses a T25 flange, while what you have is a DSM Radius flange. The 12B-20G Mitsu compressor wheels use a flat backwall design that can fit in almost any housing. There are literally hundreds of Frankenstein combinations that can fit this, eventually, if the back wall is properly machined, can even fit some Garrett wheels too. If it came as an OEM application, you're more than welcome to go through the standard mitsu catalog and search to your heart's content. Otherwise, sorry.. no go here.
Happy reading...
http://www.turbomaster.info/eng/down...mitsubishi.pdf
Old Oct 3, 2011 | 07:40 AM
wmac's Avatar
the one on the left looks like a 15g that greddy used, the one on the right looks like it could be used with the greddy kit.
here are some pics of my greddy 15g when i had it rebuilt
manifold flange
greddy used a wacky 4 bolt exhaust, making the downpipe a challenge...
here it is with the turbine housing removed (before rebuild)
Old Oct 3, 2011 | 07:50 AM
TheShodan's Avatar
Moderator
We really need to see views of that turbine housing.
Old Oct 3, 2011 | 07:58 AM
phat00civic's Avatar
I am currently using a TDO4H or a Greddy turbo. Now I could have sworn mine did not show an R like what yours represents. Now as stated if you can give us measurements we can help you out. The H is a 14G, but hopefully the pics help you on your journey.
Old Oct 3, 2011 | 05:55 PM
TheShodan's Avatar
Moderator
phat00civic is using a Greddy turbocharger and not a standard mitsubishi because you're using a T25 5 bolt internal housing. Standard mitsubishis do not use that turbine housing.
Old Oct 3, 2011 | 08:07 PM
I thought we were just looking at the compressor housing side, right? but yes it is a Greddy turbo.
Old Oct 3, 2011 | 08:14 PM
Back to the OP according to Mitsubishi:
TDO4H
This is based upon this: 49189-006 on the housing unit. Although I can not find the remaining "60"
I always use this to find out information on Mitsubishi turbos.
Old Oct 3, 2011 | 08:27 PM
TheShodan's Avatar
Moderator
^^that's what I gave him earlier. thanks.
Old Oct 4, 2011 | 11:50 PM
Ok, we tore them apart and a buddy of mine who is into turbo's WAY more than me measured all of it and found.
640=15g ex + 16c in
660=15g ex + 14g in
Both are mitsubishi with greddy modifications
Please dont kill me if I had said any of this wrong. Btw both of them need to be rebuilt so that was a boner killer
Old Oct 5, 2011 | 07:06 AM
wmac's Avatar
rebuild kits are about $55 + shipping on ebay.
as the Shodan suggested, either of the turbos could probably be mated to a greddy exhaust housing, and used with the kit.
just for reference,
TD04H-15G, greddy15g
Flange T25
Compressor:
Wheel 15G
Inducer dia- 1.625" 41.28mm
Exducer dia - 2.187" 55.55mm
Trim 55
Housing TD04H-15G
Turbine:
Wheel TD04H
Inducer dia- 2.042" 51.87mm
Exducer dia- 1.735" 44.07mm
Housing TD04H 6cm2/12cm
civic-8442-
May 7, 2009 07:18 PM
MR2bl326
Jan 25, 2007 02:37 PM
hkeum2001
Aug 24, 2006 04:39 PM
skellator_thoj
Apr 23, 2003 09:57 AM
pelotudo
Nov 30, 2002 05:50 AM
