1994 Civic DX Map sensor mixup...
I bought a 1994 Civic DX with a d15b7 in it. It seems to be missing the MAP sensor completely and is throwing codes for MAP errors. The problem is that I don't have a throttle body that allows the MAP to be mounted on it, so I'm assuming it should be a firewall mounted MAP. But I was told that the car shouldn't be taking the firewall map, it should be using the TB mounted Map. I don't know whether to buy a new TB or if a firewall map would work fine. If you guys could give me some insight it'd help a lot.
Someone used a '92 - '93 throttle body. You can either swap the throttle body or use a firewall mounted map like the guy above me said, they both work the same.
Thanks for the quick replies.
shraz
12
Jul 31, 2006 08:39 PM
