mishimoto rad/ silicon hoses question
Old Oct 2, 2011 | 06:21 PM
endwell17's Avatar
Default mishimoto rad/ silicon hoses question
close
Old Oct 3, 2011 | 04:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: mishimoto rad/ silicon hoses question
What?
Old Oct 3, 2011 | 11:38 AM
cvcrcr99's Avatar
^^That. What?
The radiator will not really change much. It can disperse heat faster than the plastic unit, thus lowering your chances of overheating. It holds more coolant, thus making it take a little bit longer for the fluid to warm up etc.
The thermostat controls the temperature of the coolant for the most part. If that is not touched, the coolant temperature will basically remain the same unless you had a known problem with the radiator prior to replacing it.
Old Oct 3, 2011 | 02:04 PM
endwell17's Avatar
ha thanks. ok well im going to install now
Old Oct 6, 2011 | 01:43 PM
endwell17's Avatar
can anyone tell me if supertech antifreeze/coolant is ok for my new rad? it says do not add water...so im guessing dont add water, just put the super tech in??
Old Oct 6, 2011 | 02:03 PM
The Grumpiest
It's 50/50. What's the problem?
Old Oct 6, 2011 | 03:12 PM
r1paniccia's Avatar
its fine just use it! yours is 100 to 1 ratio. you need to mix it down to 50 to 1. for example every cup of antifreeze you would add a cup of water to it. its not 50/50
DJester187
Jul 3, 2006 08:31 PM
icedlee
May 15, 2005 10:21 PM
budget
Apr 9, 2005 05:13 PM
LillDragun
Oct 25, 2002 04:25 PM
