del sol budget build.
Old Oct 2, 2011 | 07:37 AM
solman84's Avatar
Default del sol budget build.
hey guys i got a 94 del sol with a z6 im building. i plan on staying single cam just because to many people go dual cam and i want to stay with the orginal motor. but anyway i already have some bolt ons( dc short ram, hp racing header, high flow cat and stainless cat back. spaced throttle body) but i was looking at a powercard fuel controller. but i was wondering if there are any motors that have larger injectors that will work in my single cam without giving me any trouble.
Old Oct 2, 2011 | 08:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: del sol budget build.
No. Not without a tune or a basemap at the very least. You can't just swap bigger everything on an engine and expect corresponding power gains.
Old Oct 3, 2011 | 05:21 AM
barrett_5's Avatar
^^this. yes you can swap injectors, easily. just not without doing the tune to go along with it.
Old Oct 3, 2011 | 01:50 PM
solman84's Avatar
ok wat injectors could i use and wat is involved in tuning them? and wat r the resulting issues that occur without tuning?
Old Oct 3, 2011 | 03:37 PM
barrett_5's Avatar
If u run smaller then you cut off the fuel the engine needs and it wont get enuf. Bigger injectors mean too much fuel. You'll burn more so gas mileage will decrease and can get sparkplugs wet and they won't fire. Can also cause over wearing of the pistons since the combustion will be hotter because of the extra gas. I think. Someone correct me if I'm wrong. You could use injectors from any dsm car as long as you get a resistor box.
Old Oct 3, 2011 | 06:15 PM
The Grumpiest
Forget the bigger injectors. You have a stock Z6 with standard bolt-ons. Bigger injectors won't do much of anything even WITH a chipped, socketted and tuned ECU. You obviously didn't research this or think it through.
Old Oct 3, 2011 | 06:32 PM
evilclown312's Avatar
This ^^^^
Old Oct 13, 2011 | 02:32 PM
solman84's Avatar
no i didnt research into it. i just wanted to hear it from other people...has anyone heard of or have any expirence with a powercard controller?
Old Oct 13, 2011 | 02:42 PM
The Grumpiest
Doesn't do squat unless you're boosted. Mainly supercharged. I think it plainly says as much no matter where you look these things up.
Old Oct 13, 2011 | 02:49 PM
solman84's Avatar
ok then that will save me 130 bucks....wat would u say the life expectancy is on a z6 with stock internals and a cheap turbo.
Old Oct 13, 2011 | 02:56 PM
The Grumpiest
Put together by someone that doesn't do research and wants to take shortcuts? Less than 6 weeks.
Old Oct 13, 2011 | 03:00 PM
solman84's Avatar
dude i apreciate most of the advice that u have given but u dont need to b a dick about. this was my way of researching! i am just asking questions from people who i know can give me good answers. so do me a favor either b helpful or shut up.
Old Oct 13, 2011 | 03:01 PM
The Grumpiest
You call this research? This is like going into the library and asking the librarian to read you the books. I found out in less than five minutes what you could not in 11 days.
Old Oct 13, 2011 | 03:08 PM
solman84's Avatar
i still dont see your point i found out the same information regardless. im assuming your one of those forum guys who hate when people ask stupid questions but yet you find it necessary to post on them.
Old Oct 13, 2011 | 03:14 PM
The Grumpiest
I thought you didn't do any research? I don't get it then. Why post if you already know the answer? And you admit you asked stupid questions? Hm.
Here's the answer to your turbo question, that I know you have the answer to already, in the form of more questions.
What sized turbo? What is the horsepower goal? What is your budget?
Old Oct 13, 2011 | 03:19 PM
solman84's Avatar
my research was on here. t28 turbo. less then 180 hp. $1000 budget.
Old Oct 13, 2011 | 03:21 PM
The Grumpiest
Not for $1,000. Your research is flawed. Even if you can get the kit for less than a grand (just the parts), a tune will cost you AT LEAST $300-$500 NOT COUNTING the engine management. And I don't mean a chipped ECU from Ebay. I also suspect you are looking at an Ebay turbo kit. If you are, 6 week lifespan for the engine.
Old Oct 13, 2011 | 03:26 PM
solman84's Avatar
ok thats all i needed to know. and i do thank you for the info.
mikegyverone
Dec 2, 2013 09:11 AM
noidg101
Jan 22, 2009 04:01 PM
Frost_1097
Mar 25, 2007 07:46 PM
hot_4_hondas
Oct 6, 2005 06:18 AM
