eg f20b almost done
Old Oct 2, 2011 | 07:18 AM
egf20b's Avatar
Default eg f20b almost done
i have a 92 eg hatch that had an h23a blue top but spun a bearing the first week i had it so i swapped an f20b euro r in its place and its been a rough ride. swapping it in went smooth. i had to make an iac adapter plate which wasnt bad. then i had to solder things. i had it running like crap on a p06 that was adjusted for the h23. i got the p28 and had it tuned for the f20b and thats where the failure came in.
its been dumping fuel and fouling plugs. i changed all sensors and checked all connections. it runs crappy at low rpms with my foot to the floor for a minute before choking on fuel. i adjusted the oem regulator for the least pressure just to get it to run. i had the tuner retune for 310cc injectors because thats what ive read it has and he tuned for 290's or 270's.
before i go and point my finger at the tuner i want to make sure theres nothing i forgot. keep in mind it ran on the p06 and stopped when the p28 came in.
Old Oct 2, 2011 | 07:23 AM
grumblemarc's Avatar
The Grumpiest
Default Re: eg f20b almost done
How could it not be the tune? You didn't have fuel dumping issues until the tune. What injectors are actually ON the engine? You running a wideband? What is it reading?
Old Oct 2, 2011 | 03:25 PM
canadaek's Avatar
did you actualy go to a tuner or just find a basemap online ? there are lots of bad basemaps and chips out there make sure you get on from a reliable source. i hope it wasn't from e-bay .
Old Oct 2, 2011 | 05:23 PM
egf20b's Avatar
im in florida so i went to that speed innovations guy from ebay because hes like 15 minutes from me. he used an h22 basemap and went from there. im not running a wideband and the injectors are the stock f20b 310cc.
Old Oct 2, 2011 | 05:44 PM
egf20b's Avatar
he is a nice guy and said he WILL get the car tuned right. most of his tunes are ordered online so he has a rep to uphold.
Old Oct 3, 2011 | 02:13 PM
egf20b's Avatar
just went to the tuner and he gave me a new p28 assuming the last one was faulty but i got the same results. my last thought is his "tune," that he said worked for all the other f20b's, is just way off.
vanessabriseno8
Jan 27, 2014 10:20 PM
chump07
Aug 11, 2013 05:13 PM
jesusjdm89
15
May 8, 2012 06:21 PM
dE.fUsEd
11
Jun 11, 2009 12:21 PM
auto-accessories-inc.
14
Jul 22, 2007 01:35 PM
