Would an IAT sensor code cause an idle problem?
i have a code saying IAT - intake air temperature sensor, does that cause an idleing problem. because my car is idleing still, after i changed the iacv and the throttle body. any info would be very much appreaciated. thanks
When the IAT sensor defective idle speed may be correct, it all depends how much cheating. Damage to the sensor may be affected by the increased combustion of fuel
Please place simple tech questions directly into the thread title - edited.
If you reset the ECU, does the IAT code return? If so, is the IAT plugged in?
Yes it came back on. After I reset it and got it scan. What should I do replace the sensor or?? What ever advice would be of a real help.?
black sohc civic
Oct 30, 2005 07:02 PM
