97 integra ls w/ jdm type r swap
Old Oct 1, 2011 | 08:23 AM
FeeLOt's Avatar
Default 97 integra ls w/ jdm type r swap
First off i guess ill introduce myself, Pilot is the name. I just did a 98 jdm type r swap into my 97 LS. Im running the original jdm ecu that came with the swap. I've heard that i wont be able to get my emission pass here in nc. So i was wonderin if theres any way i can get it to pass
Old Oct 1, 2011 | 09:32 AM
sebTeggy's Avatar
Default Re: 97 integra ls w/ jdm type r swap
Get it chipped and tuned....
Maybe change your timing and hope for the best?
Sorry, im not a professional
Old Oct 1, 2011 | 09:46 AM
mouab18c1's Avatar
^^An obd2 car will not pass emissions with an obd1 ecu.
Old Oct 1, 2011 | 11:04 AM
Mr. EG's Avatar
Type R's never came in OBD1 form. He is using an OBD2 P73 most likely. OP you need to source a stock EM1 Ecu or a stock P72 that will just get you through emissions. The P73 map is too rich and the timing maps are too aggressive to pass a SMOG exam.
Old Oct 1, 2011 | 12:31 PM
mouab18c1's Avatar
To be able to tune Op would have to convert to obd1 or buy an aftermarket ems. Fyi I never said ITRs came in obd1 models. It's a stock motor that doesnt even need to be tuned.
Old Oct 1, 2011 | 01:01 PM
Mr. EG's Avatar
Sorry I mis-read your post. And correct an OBD1 ECU in an OBD2 chassis doesn't pass emissions even with a tune. He needs a stock OBD2 ECU that will run the motor a bit lean and more conservative just for emissions.
booostin
Aug 21, 2013 06:20 PM
vt_hokie2008
Dec 28, 2010 12:03 PM
envision
Nov 26, 2007 12:56 PM
tc_gts
Oct 28, 2007 12:22 PM
shadykit
Sep 19, 2004 04:02 PM
