Transmission & Drivetrain Gearboxes, Differentials, Clutches
1991 acura integra with b16
Old Oct 1, 2011 | 05:10 AM
doctorash27's Avatar
Default 1991 acura integra with b16
i have a 91 integra with a b16 swap thats chipped and tuned with the HONDATA 100 software. its great off the line and around town but in 5th gear at just over 100mph im a 6000 RPM. any trans ideas like a 6 speed or anything i can do to drop the RPMs at high speeds?
Old Oct 1, 2011 | 07:22 AM
David @ Synchrotech's Avatar
Default Re: 1991 acura integra with b16
You can change the 5th gears to the LS longer ratio.
Old Oct 1, 2011 | 08:12 AM
i hate asking stupid questions but what does LS mean? is it a kit or can i buy a trans that has LS gearing?
Old Oct 1, 2011 | 11:50 AM
The Acura Intergra LS model has a longer gear ratio than the B16. You can install the two fifth gears from an LS to lower the RPM in 5th gear and keep the close ratio 1-4.
Old Oct 2, 2011 | 04:55 AM
i visited the website and was looking under the custom gears section. is this where i should be looking and if so which application would be good for me? i noticed last evening i was at 3500RPM at 60mph in 5th gear. i dont know if that info will help steer in the right direction of what to get but i thought i should provide it. thanks for the help. also is there a complete trans i could swap to?
Old Oct 2, 2011 | 10:39 AM
ok. so im probably gonna replace the whole trans. 3rd gear grinds alot when im going into it. so what trans should i get that will bolt right up to the b16 and into the car without modification?
Old Oct 2, 2011 | 11:19 AM
There should be a gold or white sticker on your transmission with the OEM ID serial number. If it is a 88-91 cable B16 it will have code S1/Y1/or J1. You can install a USDM 1990-1991 Integra LS transmission with longer gears code S1 or A1. If you have a cable 1992-1993 B16 it will have a white sticker code YS1 and you can install a USDM YS1 1992-1993 Integra LS cable transmission.
rx191
Apr 7, 2012 02:50 PM
repingjdm
11
Feb 15, 2011 07:11 PM
tremor86
22
Dec 20, 2007 08:55 AM
DA is best
13
Jan 29, 2007 11:09 AM
TheSwift1
Jul 4, 2002 08:39 PM
